Question about Tektronix Phaser 860 Thermal Printer
Cleaning sheet needed
Printing saying cleaning sheet needed how do I solve it?
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
Black cartridge replaced still says it needs replacing?
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Kodak Printer support:
http://support.en.kodak.com/app/answers/list/p/5,62
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Kodak Office Equipment & Supplies
KODAK 5300 PRINTER IS PRINTING PICTURES WITH A PURPLE TINT TO THEM
Kodak EasyShare 5000 series
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing below standard
The problem could very well be clogged ink or air bubbles. There's no need to perform the regular cleaning any more as if it didn't solve the problem in the first few tries, it wont help, more force is needed.
You can perform a powerpurge (takes more ink, uses more force, solves more clogged ink), to perform it, follow these steps:
  • Enter maintenance mode, press menu, 2, 8, 6, 4 quickly (in two seconds).
  • When the buttons are flashing and the display says Maintenance, press 7, 6.
  • The display should now say "CLEANING ALL", press 3.
  • Now it should say something among the lines P_PURGE or POWER_P. Press Mono/Black Start.
  • After cleaning is done, you will get back to Maintenance. Press 9,9 to leave service mode again.
If the problem isn't solved now however, chemicals would probably be needed to solve it, as this is pretty much the only "function" you can use.
May 26, 2009 | Brother MFC-260C All-In-One InkJet Printer
HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Thanks, Joe
Apr 16, 2009 | HP Officejet J5780 All-In-One InkJet...
Not printing
Clean the printhead, then print a demo sheet.
  3. From the Help menu, select Maintenance, then select Printhead Cleaning. The On/Off light flashes green during the cleaning procedure.
Is the Demo printout giving the same result?
If so, you may need to replace the printhead. This is a very common problem with this model. Call Kodak, they will send you a new print head, if the unit is under warranty.
Live phone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight Eastern time, 7 days a week.
The expected wait time for phone support is 15 minutes.
Thanks, Joe
Mar 07, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My copy prints come out blurry after changing ink cartiges
Try this:
Checking the print quality:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
  4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
  5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
  6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
    If you can see missing short lines, press 2 (NO) and go to Step 7.
  7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
  8. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
  9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
  10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
Setting the Alignment:
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
    If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
    Thanks, Joe
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Tektronix Phaser 860 Thermal Printer Logo
47 people viewed this question
Top Tektronix Office Equipment & Supplies Experts
k24674
Are you a Tektronix Office Equipment and Supply Expert? Answer questions, earn points and help others
