Question about Bell BE-412CID Corded Phone
NO MANUAL HOW DELETE CALLERS IN LOG ? - Bell BE-412CID Corded Phone
  • 67 Answers
You can download the owners manual in PDF format from this link.
412CID 4 Line Telephone
To answer you question - From the owners manual:
Erasing Caller ID Records
In order to delete a specific Caller ID record in the log:
1. Using the [<] or [>] key, find the particular record you would like to delete..
2. Press the [ERASE] key. The LCD display will indicate that the record has been deleted.
3. You may erase all caller information records simultaneously by pressing [ERASE] from the summary
Call ID display.
Hope this Helps.
Posted on Sep 25, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
HOW DO I DELETE CALLERS FROM LOG
Ow this is very Easy man!
Aug 31, 2014 | Cell Phones
I want to block unwanted callers from calling me . i am unable to block these callers
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
Apr 11, 2011 | Samsung Star GT-S5233 Cell Phone
Hi, i have a vtech 6.0 and can't determine how to delete callers numbers from the caller id
I'm assuming you're talking about the directory. When you enter a number/letter, the "Mute" button serves as a backspace/delete function. So what I did was go to Menu>Directory>Review, scroll to the contact I wanted to delete, and press "Mute", which asks me to confirm to delete the contact. Hope this helps.
Sep 21, 2010 | Vtech DECT 6.0 Digital Cordless Phone
Why can callers not hear my voice on my LG KS360? Call volume is on full. Sometimes callers get no sound & sometimes very low volume.
i found the solution on the internet:
I've had this problem with mine. It got continually longer and other functions seemed to be running slower. At worst, it took 40 seconds to hear an outgoing call. I cleared the call log and that helped and it seemed to get slower again as the log got longer until I cleared it again.
I think the call log might be getting loaded in the background and using more resources as it gets larger but that's mostly a guess.
Jan 06, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Simply set up voice mail? Callers get message
u need to call the carrier to have them cancel and reregister ur voicemail profile
Oct 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Display most recent Caller ID telephone numbers not old ones
You have a 7730 PHONE. The system is not determined, but in analog going forward it could be a TA-624/824 or TAW-848.
If you have a TA system, it requires programming http://www.fixya.com/support/t2436730-caller_id_stoped_working_dont_know_clear
Carl
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
How to delete recent log contacts?
just open callregister and delete all contentshown there
Mar 22, 2008 | Cell Phones
EXECUTONE MODEL 64 Phone
quick way is to delete them both and re-record
Aug 08, 2007 | Executone 64 Corded Phone
Bell BE-412CID Corded Phone Logo
497 people viewed this question
Top Bell Lands Phones Experts
k24674
guyvstewart
ray gallant
Are you a Bell Lands Phone Expert? Answer questions, earn points and help others
