Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stops and displays F06
Washer stops and displays F6
  • 5,911 Answers
The following link explains how to troubleshoot the "F06" error code:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The first step in toubleshooting this problem is to check all the connector plugs between the Drive Motor, MCU and CCU. Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact.
NOTE: You only to check the connectors that affect the drive motor and MCU circuitry.
If the tachometer is determined to be the cause of the problem, it is part of the MCU. The MCU will require replacement. For more in depth troubleshooting tips refer to your tehcnical data sheet that came with the washer. It is located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, dianostic procedures and helpful illustrations to assist in troubleshootingwasher stops and displays F06 - 2.gif and repair of your washer.
If you have questions, or require additional assistance, please let me know.
NOTE: For better access to the toe panel screws, you can prop the two front feet of the washer up. (A 2x4 works real well for this).
Posted on Sep 25, 2009
Washer stops working and displays F6
hotpoint?
"EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Aug 24, 2015 | Washing Machines
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F6 CODE ON WHIRLPOOL WASHER
F06 -----Drive motor tachometer error
the control is unable to properly detect motor speed and the machine will shut down.if a failure occurs during high speed spin the door will be unlocked after the drum has stopped rotating.
POTENTIAL CAUSE
check the harness connections between the motor and ccu
check the tacho circuit on the motor
check the motor resistance winding
Dec 10, 2012 | Whirlpool 8182697
F06 comes up and then the machine stops
Take the front bottom panel off. You will get a tech sheet. Use it to see what an F6 error is and what steps to take to correct it.
Aug 16, 2010 | Kenmore HE2 Plus Front Load Washer
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Errore F6
Errore F6 (F06) significa problemi con il motore, o con gli ingranaggi di trasmissione del motore.
La scheda di controllo della tua lavatrice rileva che il motore non sta girando alla velocita' richiesta o e' guasto.
Di solito , quando questo si verifica il tecnico controlla il motore, la trasmissione (motor coupling), l'unita di controllo del motore MCU (motor control unit), e sostituisce la parte difettosa.
Controlla questo link per avere piu dettagli su come risolvere il problema.
Non dimenticarti di votare la soluzione, possibilmente con quattro rombi azzurri.
Grazie.
Sep 03, 2008 | Whirlpool AWT5108 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
