Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Ti-84 Plus Won't turn on
When I hit the power button a screen briefly pops up displaying "Recommend Change of Batteries" but I have changed the triple A's and I think it should work w/out a change of the back-up battery... any suggestions?
  • Anonymous Jan 01, 2008
    i changed the batteries 3 times i just got it and i click on it doesn't show me anything on the screen!
  • yoyo82792 Jan 04, 2008
    I put in new batteries but it will not turn on still.
    is it possible that i used all the back up battery so now it will not turn on ?
Ok here r m ideas...
  1. Change back up batteries
  2. GEt new triple A's from a store. u may have duds
  3. Wiring may be a lil weird
  4. Did u drop it and damage it internaly?
  5. Go 2 a professional and get help like from office max or something
Posted on Feb 06, 2008
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
Using a TI-84 Plus Silver Edition and the screen just went blank in the middle of a class. changed the batteries, didn't help. cleaned the connectors, didn't help. tried to change the resoluti
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
What do you mean by "changed the resolution"?
Nov 15, 2012 | Texas Instruments TI-84 Plus Silver...
My TI-84 plus silver edition calculator crashed after my little sister held the "2nd" button and then pressed the down arrow key. The screen showed a 4, 3, 2, 1 countdown and then blanked out. I...
If your little sister did as you say, then the logical way to handle the problem is to revert the process.
  1. Press [2nd] button and release it.
  2. Press and HOLD the UpArrow.
  3. As you keep pressing, the top right of the screen will show a series a number, starting with 3 maybe, as you cannot see the 1 or 2, and the display will darken.
  4. Maintain pressure on, till the display is to your liking.
Jun 16, 2011 | Texas Instruments TI-84 Plus Calculator
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 17, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 won't turn on. If I replace the
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
May 15, 2010 | Texas Instruments TI-84 Plus Silver...
I changed the batteries in my ti-84 and it will not turn on.
Double check that all the batteries are new, and that they are all completely in and in correctly. Also, it may be an issue of screen contrast. Hit the "2nd" button and then press and hold the up arrow. If you don't see anything, press "On" and try the same process again.
Jan 26, 2010 | Texas Instruments TI-84 Plus Calculator
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
Ti 84 plus problem
The calculator only displays from -10 to 10 on the x and y axes, and both of your lines are outside of that range. However, it is easy to change that.
1. Hit the gray "WINDOW" button that is directly under the screen
2. Change "Xmax" to 150
3. Change "Ymax" to 200
Remember to change both of those values back to 10 when you are done with this problem!
Here's how to graph it:
1. Hit the "Y=" button
2. Enter your first equation after Y1, and your second equation after Y2
3. Look over both the equations to make sure you typed them correctly
4. Hit the "GRAPH" button
5. If you don't see the intersection you will need to adjust Xmax and Ymax again
6. Hit Hit "2ND" and the "TRACE" to bring up the "CALC" menu
7. Scroll down to "intersect" and hit enter
8. Hit enter 3 times (You use the first and second curve options when you have more than 2 lines)
9. It should display the coordinates at the bottom
10. I got (76, 142.1) for the intersection
Thanks for asking this question! I used to do this a much harder way, but while I was calculating the answer to your question I hit a wrong button and accidentally found this method!
Jun 30, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
113 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
