Question about HP Computers & Internet
Just tried to install a new ATA DVD drive in my HP A1240a desktop. would not powerup. went back to original configuration and still will not power up. no fans turn. no light on front button. is there a hidden fuse for the PowerSupply?
  • m9moody Sep 25, 2009
    Thanks for your response. Don't have an I/O switch on PSU or a separate Reset button on front. Did check the mobo and CPU connectors. All okay but still no power up or fan turn on. There is a green light on the back of the PSU and it blinks fast when power plug is inserted. Slow for a while when the power plug is off.
    found mother board causing power supply flashing greenlight. Thanks.
    Scholar:
  • 78 Answers
Check the I/O switch on the back of the PSU, make sure it's set to I.
Check the mobo and CPU power connectors from your PSU to the motherboard.
Push in the Reset button (in front of case) first, then try Power button (some motherboards want the reset pushed first before re-booting after being completely powered down.)
-J
Posted on Sep 25, 2009
  • 98 Answers
Find the switch wires. You may have moved them a little when you put the drive in now it's not getting a connection. Mine does it all the time if I open it up. unplug it amd plug it back. the fuse for the power supply is in the power supply box. You will have to take it off and open it up.
Ken
Error Message: Drive 2 not found: Parallel ATA, PATA-0 (PRI IDE MASTER)
Anonymous,
Did you set the jumper on the drive to cable select? Check to what the jumpers on the back of the drive is set to. You should have 3 selections. primary,secondary and cable select.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 21, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Adapter for cd/dvd power cable inside
Being that you didn't give detail about the pin configuration on the drive vs the cable (ATA to SATA, SCSI), You could return to the place you purchased from and have them correct the cable issue. 2. You could visit Radio Shack, Best Buy, etc to get an adaptor that will connect the two together.
Good Luck
C2S
Dec 22, 2011 | HP Compaq Presario SR2150NX PC Desktop
Hi, Maxtor 90645D3 hardrive deletion manual jumpersettings.
Basic jumper settings for Maxtor ATA Hard Drives
Thank you for purchasing your new ATA hard drive from Other World Computing! Please
review these jumper settings prior to installing your new hard drive into your computer.
You may want to review more detailed information about the installation process, or
the location and configuration of your existing internal ATA drive before proceeding.
Your manual that came with your computer can be of assistance in both of these
determinations.
A few notes about installing an ATA hard drive into your existing system:
Your existing drive is normally configured one of two ways, Master (single drive), or
Cable Select. You will want to determine this before installing your new drive, the easiest
way is to remove the existing drive from your system and visually inspect it's hard drive
jumpers. Most hard drives have a schematic either silk screened onto the case of the
drive, or the schematic is on a label near the jumper pins. If you have difficulty locating
this information, visit the hard drive manufacturer's website.
If your existing hard drive is configured as "Master", then set your new hard drive
to "Slave". If your existing drive is set for "Cable Select", then set your new drive to
"Cable Select" also. You can change the existing jumper settings on the original drive
to suit your needs, but we recommend following these instructions first to verify proper
operation of the new hard drive.
Installing jumpers on the new drive is a simple process, follow the schematic to
configure your drive.
Please note the configuration of
the internal ATA cable already
installed in your existing system.
If your internal cable is configured
differently than pictured here,
you may want to replace it before
installing a new hard drive to
achieve maximum performance.
For further assistance, visit our tech center at http://eshop.macsales.com/Tech/index.cfm
Mar 10, 2011 | Computers & Internet
Does this hp dc5100 use sata drives
Yes it uses Sata drives.So if you are planning to use sata drive then you can.Your hp dc5100 uses sata drives.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 20, 2010 | HP Compaq dc5100 Small Form Factor PC...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Can I install a hard drive in an HP Pavilion 6736 which has a capacity greater than 20GB ? If so, is there an upper limit to the capacity..can I install a 120 GB drive?
The size is not an issue with the hardware normally. Usually it has to do with the operating system. If you are running an OS like windows xp you should have no problem.
Just make sure you are using the SAME type interface hard drive. Example PATA Parallel ATA, or Serial ATA (SATA).
May 04, 2010 | HP Pavilion 6736 PC Desktop
Needs new hard drive. Which hard drives are compatable and can I install a new hard drive and then simply insert the recovery disc to install the original programs and go from there with the upgrades...
According to HP's specifications, your computer came with a 250GB SATA (serial ATA) hard drive. All drives have standard mounting dimensions, so any SATA drive would be compatible. HP has manuals here that give detailed steps on how to change the drive if you need help. It's a very simple process. Then yes, just put in your recovery disc and reload the original software. You'll then need to reinstall updates, any applications you put on, and so on.
Hope this gets you running again soon. Thanks for using Fixya!
Feb 10, 2010 | HP Pavilion a830n (PP166AA#ABA) PC Desktop
WebCam & DVD not working
I want you to physically remove your DVD rom for your unit - locking screw located in the belly area with a sort of clock symbol - under power hit ejest to open the dvd drawer - then with the screw removed & unit powered off gently pull the dvd unit out then power the unit on - you'll most likely find the webcam will be ok. It's called and ECD502 device access error. there is a firmware and bios fix for your unit on the HP.COM website.
Jul 16, 2009 | HP Pavilion dv6000z Notebook
Added ide hd and can't boot from ata hd now!
Ah, ok. According to the manual, on page 1-23...here's what you need to do.
According to this page, you need to set onboard ide operate mode to "Enchanced Mode", and Enchanged mode support on to "Sata".
Sep 17, 2008 | ASUS P4P800S Motherboard
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
