Question about Drills
Where can i get a coleman powermate 18v power supply for a cordless drill?
I'm looking for an 18volt batterie transformer for my coleman powermate drill, my transformer stopped working, and can't find one.
Thank You
Douglas Jonatzke
sjonatzke1@verizon.net
Posted on Feb 20, 2010
  • Jack Coats
    Jack Coats Aug 31, 2010
    I have the same issue, but determined it is the charge controller inside the base and not the transformer. It has one item that looks similar to a little disc capacitor and two resistors. I can't find the part number on the little disc capacitor looking item, but I bet that is what is wrong with mine anyway.
Need battery 18volt d c for power glide drill motor can I get it here? 60101230?
These are my go to people for batteries and the service is A1. They will supply.
Battery Buyer Batterybuyer com
Oct 30, 2016 | Drills
18v battery for nutool cordless drill
How To fix: Zap a Dead Cordless Drill Battery (nicad repair ...
? 5:56
https://www.youtube.com/watch?v=g0JbNX4K4fQ
Apr 27, 2010 - Uploaded by froshmasta
Got an awesome cordless drill with dead nicad battery packs and don't want to throw it out? Maybe a welder ...
Nutool Cordless Drill Kit (18v) x2 BATTERIES - Amazon.co.uk
www.amazon.co.uk > ... > Drills > Drill Sets
Amazon.com, Inc.
Rating: 3 - ‎1 review
Buy Nutool Cordless Drill Kit (18v) x2 BATTERIES at Amazon UK. Free delivery on eligible orders.
18v battery for nutool cordless drill - Fixya
Jan 14, 2016 | Drills
Coleman 18 volt battery and charger
Typically, nothing will fit it except a Coleman battery, but you can try. Be sure to test before you buy, and you will need to be really sure the voltage is the same. Be blessed.
May 11, 2013 | Coleman Powermate 18 Volt Cordless Sander,...
I need a charger for the Coleman Powermate drill PMD 8129
I have a powermate 18v reciprocating saw that is missing the small tab that holds the blade in place..How can I get one?
Jan 24, 2011 | Coleman Cable Coleman 18 Volt Combo Drill...
How to flash or remagnitize Coleman Powermate 6875 or Husky 40500
Field Flashing of Portable Generators This tip comes from the Briggs & Stratton Customer Education Department. As an alternative to flashing a rotor winding with a battery applied to the brushes, an electric drill may be used. Follow these steps to flash the generator:
  • Plug the electric drill into the generator receptacle. (Cordless drills do not work)
  • If the drill is reversible, move the direction switch to the forward position.
  • Start the generator
  • While depressing the trigger on the drill, spin the drill chuck in reverse direction. This will excite the field and the generator will now produce electricity. If spinning the chuck one direction does not work, try spinning the chuck in the other direction as you may have the reverse switch positioned backwards.
Use caution not to get your hand or other materials caught in the chuck. As soon as the field is excited, the generator will produce power and the drill will turn on.
The reason this works is because the electric motor in the drill will act as a small generator when spun backwards. The magnets in the drill's motor induce a voltage into the motor windings, which is fed back through the trigger, cord and into the generators receptacle. From there it goes into the power winding of the stator. The voltage going through the power winding creates a magnetic field, which is intensified due to the iron core of the stator laminations. The rotor intersects this magnetic field as it is spun past the power winding, thus inducing a voltage in the rotor winding. Once current flow is present in the rotor winding the rotor has been flashed.
If flashing the field does not make the generator work, you may have additional problems, besides a lack of magnetism in the rotor. Further testing will be needed. Hopefully, this will give a simple way to field flash your generator if needed - Bruce Perrault
Apr 27, 2010 | Coleman Powermate Powermate 5000W...
Delta cordless power tool batteries, #CL180B
battery world or the like will be able to supply new ones or repack your own
Sep 13, 2009 | Drills
Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA  The one I have is a Ktec Model KA12D240020034U
Aug 29, 2009 | Coleman Drills
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
My powermate pm0647000 stopped generating electricity.
Flash it !
Start your generator, plug a single speed drill into the recepticle, while the generator is running make sure the drill is in the forward posistion then turn the drill chuck couterclockwise with your hand untill your generator power's up.
This simple fix " excites " the stator.
Good luck !
Sep 29, 2008 | Coleman Powermate Premium Plus 6250W...
Drills Logo
1,166 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
