Question about Roxio Easy VHS to DVD for PC
Not reading disc when trying to copy my own audio tapes
  • 729 Answers
Hi keith_mor781
It sounds like that some connections to your VHS is not working, make sure that the cables are connected properly. to do that then disconnect and reconnect the cables, reboot the machine and retry.
OR/AND
contact ROXIO support here :
https://selfserve.roxio.com/%28S%28yf5sgp551cgeck55ahsc2p55%29%29/Login.aspx
Just REGISTER, and then contact them and tell them :
Which kind of software you use and version number, and what you are doing to record the VHS cassette, (which buttons you press on )
Hope it helps
Have a nice weekend
Please rate my answer
Posted on Sep 25, 2009
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Im getting a message that says "this disc requires on-the fly copying" What does that mean?
which burning software are you using
When using the on-the-fly method, insert the original disc into a drive and a recordable disc into the drive. The original disc in the drive is copied immediately without any time delay to the blank disc in the recorder. The on-the-fly method allows you to copy discs very quickly, and does not require any additional space on the disc.
In order to be able to use the on-the-fly method, you will need at least two drives: one for reading the disc and a disc burner for writing. The following requirements apply to the read drive and disc burner:
· The disc burner must feature buffer underrun protection, or the drive must be capable of delivering the data sufficiently quickly. The read speed should be at least twice as fast as the write speed.
· The read drive must be capable of delivering information on the number and type of sessions, otherwise Nero Burning ROM may not be able to produce an exact copy.
If you want to copy Audio CDs, we recommend the copy image method because the quality of the read audio files can suffer depending on the drive.
Hope this helps
Jul 06, 2011 | Toshiba Computers & Internet
I have inherited a Sanyo 3-disc CD changer system with radio and tape-to-tape deck. When I tried to put a CD (a copy made on my computer) into the system it would not play, so thinking it wanted a...
i have the same problem and when I opened it I noticed that it wasn't spinning the disc fast enough, if anyone knows how to fix this or if we can just swap the motor please help!!
Sep 17, 2010 | Audio Players & Recorders
Laptop cant detect discs
Hi, Unfortunalty this is an hardware failure there is nothing you can do. If you are under warranty i suggest you to contact the reseller/manufacturer to get a replacement unit, it should be no problem at all this is a common issue. HDD,batteries,power adapter are the weakiest part of your system and generate the heaviest part of hardware failure on computers.
Thanks and have a nice day J -
Jun 09, 2010 | Computers & Internet
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Recording from video tape vhs to dvd discs
Should be straightforward: audio and video out from VCR goes to audio and video in on your DVD recorder. If using computer, they go into same inputs on AV card or dongle. Your AV capture software should take it from there.
Any DVD will work in most players, but some are quirky; if so, try DVD+R.
Commercially produced tapes usually have some form of copy protection that cannot be overcome without the use of third-party devices, which may or may not be legal. I'm no expert on copyright law, let alone a lawyer, so I don't know. I do know that if one has the rights to make a copy, devices in the class of "image stabilizers" seem to make it possible in many cases.
Jun 26, 2009 | Panasonic DMR-ES10 DVD Recorder
How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Dec 30, 2008 | Samsung DVD-V4600 DVD Player/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
DVD-VR357: Copy multiple vhs tapes to one DVD?
Try using DVD/RW disks with pausing the recording when you change VHS tapes.
Dec 22, 2007 | Samsung DVD-VR357
Trying to finalize a cd
Hi, This is just a guess but it may be worth a try. I have heard that Audio CD-Rs, which are the only media this machine will record onto, are famous for being finicky about being played on different kinds of CD readers. My suggestion is that you "rip" the Audio CD-R's content to your computer (in .wav or .MP3 format) and then make a copy of your album onto a reagular CD-R which is more likely to be played on any CD reader. Not sure if this'll work for you but it's worth a shot. Hope this helps.
Jul 31, 2007 | Teac GF-350 CD Shelf System
Roxio Easy VHS to DVD for PC Logo
53 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
