Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
SCREEN WENT BLACK AND WILL NOT COME BACK ON
SCREEN JUST WENT BLACK WAS WATCHING IT AND THEN OUT IT WENT>>>?
My vizio E55Oi-B2E LED TV SCREEN WENT BLACK. WAS WATCHING IT WENT BLACK THEN CAME BACK THEN BLACK AGING NOW JUST BLACK
Main digital board fault. Contact any service technician. An update is necessary after the main board replacement. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 20, 2017 | Vizio Televison & Video
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
The screen went black
LCD sets use either a fluorescent backlight or LEDs if newer. If your set uses the fluorescent type, either the lamp itself or the inverter that produces the 'strike' (high) voltage for it has failed.Inverter failures are pretty common but the lamp life in in 5-digits of hours (probably >10,000 hrs)
Dec 31, 2011 | Element ELCHW402 40 in. LCD HDTV
I was watching a movie and the sceen went black i had audio though.i restarted the computer and now no video black screen. did the video card **** out? video card is a nivia 8600 gt
If you are using a lcd monitor, it is very possible that your monitor backlight failed, have you tried connecting a different monitor to check your video adapter?
If the backlight failed, the image is on the screen, but is not visible unless you shine a light on to the screen
Feb 23, 2011 | Evga nForce 680i SLI (122CKNF68)...
TV screen went black as I was watching.
if theres nothing at all (sound and vedeo) then the power supply section may check, fuse, power I.C. or transistor
Jul 31, 2009 | Televison & Video
Techwood HDMI 32'' TV - Went to black screen while watching
Am Martyn...ma Tv same model did the same thing this mornign while i played FIFA 2010 world cup on PS3 Fat...what could be the problem???
Jun 14, 2009 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
BLACK SCREEN, AUDIO OK
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Aug 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
37 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
