Question about Canon PIXMA MP780 All-In-One InkJet Printer
Not getting any black copies
The copier seems to be working only with colored copies. When i copy in black and white i am not getting any prints whatsoever. Also the ink cartridges are full so i am wondering what the problem is.
old marine
  • 2153 Answers
SOURCE: giving the error e 2,3
Go to this link. Type "error e 2 3" in the search window and click the Search button. Try the troubleshooting steps provided. If the error still persists, you may need to have the machine serviced.
Posted on Apr 30, 2008
SOURCE: Blank copies
I've tried everything before for months... unplugging, new cartridges, servicing, etc. I've always avoided jarring an electronic item, but hitting the front fixed it! A couple of open-palmed smacks above the paper drawer, and it printed this very page. Apparently, sometimes the cover over the laser sticks shut after replacing the print cartridge, or removing a paper jam. Sounds crazy, but smack it!
Posted on Jun 16, 2008
SOURCE: won't print with just black ink cartridge
A part solution is print/properties/maintenance/ink cartridge settings/select black only.
You do initially have to buy another color cartridge but you won'thave to buy another expensive color cartridge again in the future.
I
Posted on Jan 12, 2009
old marine
  • 2153 Answers
SOURCE: This Canon MP530 will print a nozzle check with no
On your nozzle check, do you see the grid at the top (indicated by red arrow in picture below)? If you don't see this, your pigment black nozzles aren't working. The black bar at the bottom is from the dye black nozzles (small black tank). You may have either plugged nozzles or a bad print head.
Posted on Mar 03, 2010
CW Oly
  • 240 Answers
SOURCE: ink absorber is full
Waste ink is full. The printer needs servicing. Can be done yourself, though EXTREMELY MESSY! And you'll need to find how to reset the counter, or just look here:
http://www.fixya.com/support/t1987764-canon_mx310_wase_ink_full_any_ideas
The waste ink pad is a huge and dirty job. It requires nearly full disassembly of the machine and full washing and drying of the waste ink pads. Resetting the counter without cleaning the pads will result in waste ink overflowing out of your printer and on to what ever the printer is on. As for printer disassembly, service manuals are not generally available for consumer grade machines, which means you're on your own. Having torn down many machine's myself I can tell you it takes time, patience and a good memory. Take good note of where everything came from and how it goes back together.
Posted on Apr 02, 2010
Can you print only black and white copies, and how to get printer set this way
go to the printer settings and click black white print only apply settings
Feb 22, 2016 | Epson Office Equipment & Supplies
How do I get the printer to print in color?
Get Into Printer Settings--Make Sure Color Print Box Is Checked.
Mar 07, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Can not get printer to print in black and white
Hi, May be you printer had been set auto color. To set it manually, go to printer setup in your computer. Select you file you wish to print the click print. On pop up printer set up you should see Canon MP 210 series printer. Then Click properties, you can see now the printer options like media, quality, paper source, color, greysacle and priview. Click greyscale to get monochrome printing.click Ok and Ok again. You should get a black white ( BW) printing result. In addition, to duplicate the file to get hard copies from your printer press Black button before do copying to get non color hard copy.
Dec 07, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My printer copy's in color but prints photos in black and white,
Check your settings for your printer software program, change it to black and white, and then you will need to change it back to color, if you want to print in color.
Aug 10, 2009 | Office Equipment & Supplies
12 black and white copies per minute
be sure you are selecting B&W when copying, and the same if printing from the print driver.
Speed is based on 8`1/2 x11 paper fed side ways. First copy speed not incluced, once the first copy exits the machine it should work at the rated speed.
Hope this is of some help.
Ed
Apr 22, 2009 | HP Office Equipment & Supplies
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Won't print black and white, looks blue
Hi
HP uses a system for black that prints a base ie: Cyan / *blue then overprints it with black...
Sounds like you are either out of black or you have an ink clog?
If so... you need to use a print head cleaner like Magic Inkjet Flush you can get a kit on Ebay.
Good Luck!
Apr 09, 2008 | HP OfficeJet r40 InkJet Printer
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
14 people viewed this question
old marine
old marine
