Question about Whirlpool Dryers
When i set the time on dryer and then push the button to start then dryer will run for a few minutes but then stops but still has a ticking noise
  • Whirlpool Master
  • 7,482 Answers
Your problem could be a faulty timer.
Watch the time and see if it rotates to different cycles. If it does not rotate to different cycles then you may need to replace the timer switch
Posted on Sep 26, 2009
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Dryer drum want turn
I am hoping the problem is the belt. One way to tell is to put your ear to the machine and start it, and see if you can hear the mortor whirring. You should. If so, the machine should be needing a new belt. Most belts last about 5 years. If there is no noise of the motor, you may have either a defective door swirtch ( they are cheap plastic) or you may have an electrical issue.
Be blessed.
Jun 15, 2013 | Kenmore Dryers
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 30, 2011 | Dryers
I have a kenmore front load dryer 80 series and it just stopped working. When you push the start button the timer button makes a ticking noise. What is wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 25, 2010 | Dryers
Dry want start
you will nead a nother person to help you make this test.first open the dryer door,next put the timer on timed cycle.with your right hand hold in the door switch,next have someone push the start button and at the same time take your left hand and turn the tub clockwise.if it starts than you have a bad moter.the age of the dryer will determin wether it is worth fixing.
Jan 23, 2010 | Whirlpool LER4634J Electric Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Nov 09, 2008 | Dryers
Dryers Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
