Steinberg Nuendo 3 for PC Logo
Posted on Sep 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No protection device connected
When loading it stops and says "no protection device connected". It ask to rety or cancel. I hit cancel and it warns my of a possible crash. Is there something I can download to remedy this?
timoboon2
Level 2:
Sergeant:
  • Steinberg Expert 360 Answers
  • Posted on Jan 15, 2019
timoboon2
Steinberg Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154610
Points
959
Try to uninstall all components from nuendo and reinstall them. Mostly this is the remedy.
1helpful
How do I root my 1100 Vodafone
  1. Switch off your phone.
  2. Press and hold Power + Volume UP buttons to boot into stock recovery.
    ? Once in recovery mode, use Volume buttons to navigate up & down between options and Power button to select an option.
  3. Select language for recovery (if asked) then proceed to set write protect off:
    1. Change it to Set write protect off.? A message will pop-up saying "Write protect is off after reboot", choose cancel.
    2. Reboot phone.
  4. Download and install the Kingroot .apk file from the link above.
    ? If you get a prompt to "Allow Google to regularly check device activity for security problems..", make sure you DECLINE it.
  5. Once installed, open Kingroot app and press the "Start root" button to begin the rooting process.
  6. During the process you might repeated warnings by Google to check device activity, DECLINE it like you previously did in Step 1.
  7. If the process finishes successfully, then congratulations! You're rooted.
    ? To verify root access, download the root checker app Play Store.
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Im Yasein From Egypt i have HTC TOUCH P3450 Mobile written back movistar Mobile and the Spanish language and I want Windows or English Arabyalmobail works with Windows 6 Professional and I wish you any...
hi yasein, what version of windows is on your pc?
download these two files and extract both
this one is the spl installer which needs to be run on your computer, if you get an error you will need to use the next download on the phone first
http://www.mediafire.com/download.php?sspbx0b1o3dqmtl
this next one needs to be extracted and then copied to your phone and then opened on the phone itself to be installed
http://www.mediafire.com/download.php?dvubl37qzaw2mh0
Please make sure Activesync is enabled (green icon in systray)
and hit ENTER to start...
STEP 1/3......50.......75.....100.
The next step will load a patched bootloader (SPL) on your device
it will make your device temporary SuperCID (seclevel=0), and will
avoid modelID and signature checking when flashing NBH files.
Hit ENTER to continue...
STEP 2/3.....15......25....50....75......100.
Phone screen should now be blank and the activesync icon gray
if not, the loading procedure has failed and you'll have to repeat again.
If all was OK hit ENTER and the standard "PDA Phone ROM Update Utility"
window will start, allowing you to flash patched SPL on your device.
Hit CTRL+C to Cancel or ENTER to continue...
Follow the steps on the wizard to flash the patched SPL, when this
step completes your device will reboot.
STEP 3/3 - Launching RUU, please wait...
Process is finished, congratulations!
If you find it useful don't forget to donate :)
(c)2007 pof - XDA Developers
Hit ENTER to quit.
Hit ENTER to quit.
then follow these instructions
STEP 1/3......50......75....100
STEP 2/3.....15......25....50...75.....100
Hit ENTER to quit.
if you have had success with installing the first file and it has completed without error then you can now download this file
http://andrewloh.com/HTC/New_Blue_Touch_ROM_V4.0.zip
extract all files in it and run the ruu_setup file in there and follow
th instructions on screen. When its finished you will have wm6.1 in
english installed on your phone
Error f 02 i need to reset this please help.
Clean out the pump filter and check that the drain hose isn't blocked. Hit cancel twice after you have done that. It should reset if not...
De-power the machine and switch on. it should reset, if not hit cancel twice.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
2helpful
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped...
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
3helpful
Lights Blink washer wont start
Check user manual for programme reset , but poss. hold start button on for minute or try same with cancel button.
F-9 warning with buzzer
try unplugging for a few hours. If this does not correct the problem which it should, make sure the door latch is releasing and latching when door opens and closes.
also make sure door is locked before turning to clean.
How do i stop the tv guide plus from loading?
when this has happened to me in the past; if I remember correctly I hit home, stop, cancel, etc any of those gets it to send me the banner that if I stop now......it is not going to CANCEL loading!!! I'm thinking YEAH!!! and then I select the prompt to cancel. I then hit menu again, to cancel and I believe I select home...Now perhaps you think I SOUND a bit "iffy" it would be true; seeing how it has been at least 3 months since it has happened and I sure not going to go and hit that ****** to walk you thru it(he he) sorry but I know you know how it is!!! GOOD LUCK DON'T GIVE UP AND DO YOUR BEST TO NEVER HIT THAT TVGUIDE+ AGAIN (i have many times and its always a pain in my brain)
now get her done!
96helpful
4answers
Device password????
Device ownership password:
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Top Steinberg Computers & Internet Experts
 Grubhead
Grubhead
Tesfay
Tesfay
Arcane Winzel...
Level 1 Expert
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
