Question about HP LaserJet 5100 Printer
Getting a 57.1 printing error - HP LaserJet 5100 Printer
  • 81 Answers
This error indicates there's a problem with the cooling fan.Usually the one on the left hand side.It's probably clogged up with dust which slows it's rotation resulting in the error you are getting.
Posted on Jan 25, 2010
57.01 error
You do not state which HP printer you have but the 57 errors all indicate a problem with one fan or another. For instance, on an M4345 the 57.01 error would indicate that the cooling fan for the DC controller is not working.Here is a list of 57 errors by model Hp Error Code 57 Service Errors Codes 57 Tech Support
Sep 07, 2015 | Office Equipment & Supplies
Had a paper jam - now removed but comes up with an error 5703
57.XX ERROR Control Panel Message 57.XX ERROR For help press c00244025.gif alternates with To continue turn off then on Description A temporary printing error occurred in one of the printer fans. Action Turn the printer power off and then on. If the message persists, contact an HP-authorized service or support provider. Click here to locate an HP-authorized service or support provider via the HP Web site at http://welcome.hp.com/country/us/en/wwcontact.html.
Feb 21, 2011 | HP LaserJet 2420 Printer
I set up my printer to print A10 envelopes and succeeded but now I want to print letter size paper and it sits on 05 Self Test then 57 Service.
57 is a motor error. You need to replace your motor. I saw one on ebay for 12 bucks. Easy to replace. Just remove the top the right side panel and you will see the motor. un-plug it and remove 4 screws and its out. Steven 818-888-0006
Mar 12, 2010 | HP LaserJet 4 plus Printer
Still getting Print Cartridge Error after installing new HP cartr
please check the position of the catridges installed. it should be in a correct position. or you might have replaced the catridges in a wrong slot. if it does not work out then either connect your printer to different computer for printing or uninstall the software from your computer, then again reinstall the software.
Oct 29, 2009 | HP Officejet 5510 All-In-One Thermal...
57.03 error
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
Cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Problems with hp laserjet 3330
hi,
i think you need to replace the fan of your printer cause maybe they reach temperature level that's why you experiencing that error...
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though...
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Jul 07, 2008 | HP Office Equipment & Supplies
Error #57 unable to connect DHCP Svr
Sometimes you can unplug the printer for approximately 20 to 30 minutes to allow the memory to clear and everything should go back to normal. If not try the next steps I have given you. Error 57 is a main motor error. Remove the toner cartridge and see if the error goes away. If not then remove the fuser in the back with the power off. Lower back cover and remove two screws and slide out carefully. Turn the gear on the fuser to see if the rollers turn. If it is binded then the fuser is the issue and needs to be replaced. Check the gears on the right side to make sure nothing has fallen in and stops them from turning. If all ok, then the main motor needs to be replaced.
Aug 17, 2007 | HP Jetdirect 615n Print Server
HP LaserJet 5100 Printer Logo
207 people viewed this question
Seeker5211
Seeker5211
