XRX-8X shredder is jammed. Can I safely open
XRX-8X shredder is jammed. Can I safely open mechanism to clean teeth?
    President:
  • 3,085 Answers
Soak the clog with soapy water,,,,seriously
Posted on Sep 25, 2009
Indicates jam. Why won't it move forward or reverse?
Some material that can't be shredded is lodged in the mechanism. The drive motor may have sensed thermal overload and stopped working either permanently or until the shredder is unclogged. Obviously, you will have to get access to the grinding mechanism and (with power disconnected) remove the jamming material bit by bit.
Sep 29, 2015 | Office Equipment & Supplies
Jammed shredder
If your Ativa shredder has a bin, you can gain access to the shredding mechanism by removing the bin and turning the shredder upside down. With power disconnected, be prepared to spend considerable time picking out bits and pieces of material. Tweezers and a utility knife are useful tools. Eventually your shredder will be back in working order.
Feb 28, 2014 | Ativa MDM6000 6-Sheet Micro-Cut Shredder
My omnitech shredder OT-NXC8PA stopped working after clearing a paper jam. Seems the machine is running, but not sucking papers.
I think you just fried your gears. The motor is fine, but the gears that connect the motor to the shredding mechanism have had the teeth flattened up. No teeth on the gears = not shredding papers. The gears are made of plastic anyway.
Jun 26, 2011 | Aurora Electronics AS1015CD Cross-Cut...
Thanks! I have a 7x Crosscut Paper Shredder, Model # PCUA:29053U. The teeth are jammed due to I believe a build up of paper. I have run it on reverse & tried to pick out the paper. The motor runs but...
If the motor runs but the cutting teeth dont turn then you have stripped or broken a gear in the drive train. You can get replacement parts from Royal at 1-800-524-0799.
Oct 19, 2010 | Royal Office Equipment & Supplies
Stopped working. will operate in reverse only
When shredders only work in reverse, it typically means that they are really jammed up. First thing to do is to UNPLUG the shredder. Then, take a look at the underside of the teeth. You will most likely see a bunch of paper sticking out, if so, try to remove it. I would advise against using your fingers, though.
As a last resort, get someone who is mechanically inclined to take the head unit apart to remove the jammed pieces. Unfortunately, once this happens, it often spells an early demise for the shredder. I have gone through three of these things for the very same reason.
Mar 19, 2009 | Intimus 250 Shredder
Shredder will not cut paper makes but reverse works
more details?
does it turn on , start to cut but jam up ,,,
Unplug unit , open it up and clean out the cutting teeth with a pik or screwdriver vacum or blow it off with air . then try
Dec 02, 2008 | OfficeMax 0M96431 Shredder
Office Max Shredder #OM96146
Don't open it, check on product warranty policy and take it back or send it in.
Jun 03, 2008 | OfficeMax 0M96431 Shredder
Jammed shredder
try shredding a old card, carefully but forcibly push the jammed plastic strip through the teeth.
might be faulty alignment of teeth, a factory defect!
May 07, 2008 | Aurora Electronics AS882C (Cross-Cut)...
Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Jun 21, 2007 | Royal 150MX Cross-Cut Shredder
360 people viewed this question
k24674
