Question about Tomtom GO 720 GPS Receiver
How can i enter my pictures in my tomtom - Tomtom GO 720 GPS Receiver
How do you insert a space in a postcode in tom tom one. I want to enter BT2 7FE but cannot see a way of entering the space
you dont need to enter a space, if it doesnt allow you to enter a 7 digit postcode then you need to update it with tomtom home
Mar 27, 2011 | Tomtom One Europe v2 GPS Receiver
What is the bluetooth passkey code?
When you are pairing your TOMTOM with a BlueTooth-enabled cellular phone, your TomTom will ask you to enter "0000" when the phone asks for a pin. In order not to have to enter the pass code every time you want to connect to the phone, declare the TomTom as a trusted device.
When you are pairing the two make sure that the phone is "visible for xxxx minutes" or "always visible".
Jan 25, 2010 | Tomtom GO 920 GPS Receiver
Need a numeric passkey for tomtom one xl to enter into the blackberry 8830
try this, pair from the tomtom and not your BB, set your blackberry's bluetooth to discoverable.
from the tomtom search for BT devices, your BB should show up, connect to it, and when asked for a passkey try entering 1234 or 0000. if those dont work your BB should show that the tomtom is attempting to connect and should ask you whether to accept or deny, it may then ask for a passkey which you specify on your BB which you then enter on the tomtom
Jul 08, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Tomtom keeps loosing GPS SIGNAL AND TAKES LONG TIME TO COME BACK
Plug in your tomtom and open my computer. Make note of the driver letter next to the tomtom symbol. Click Start, run (or search on vista or windows 7) and type in "CMD" without quotes and hit enter. a black window will open. type the letter you noted in my computer followed by a colon. Example: F: and press enter.
then type "chkdsk /f" without quotes and press enter. Answer yes to all the following prompts. once completed "takes less than a minute" type exit.
You can also try tomtom backup and then restore.
Apr 20, 2009 | Tomtom GO GPS Receiver
Cannot seem to enter mu home address
if it is tomtom then
Tap "Change Home Location" button to set or change your Home location.
or
download tomtom manual
go to tomtom website ----> support scroll down at the right hand side click Find downloads
Apr 15, 2009 | GPS
My 720 frozen
This solution can be used in the following situations:
• The device hangs in the start screen (splash screen )
• An SD-card with a red cross is displayed on the screen
• A picture with a red dot and white cross is displayed
• The device can’t be turned off
If you haven't already done so, please download and Install TomTom Home from http://www.tomtom.com/7602
If you don’t have a full backup of your TomTom yet we advise you to make one before continuing with the steps in this email. You can make a backup by following the steps below:
1. Reset your TomTom device: http://www.tomtom.com/6965 and connect it to your computer.
2. Click on 'Backup and Restore -> Backup' in TomTom Home 2.0
3. Enter a name for the backup and click [OK]
• IMPORTANT: When the software is asking to delete parts from the backup click [NO]
After the backup is made you delete the files from the root directory of the TomTom. Follow the steps below to do this:
2. Open My Computer in Windows, or Finder in Macintosh from your desktop and turn on your TomTom device.
3. On your screen a new removable disk appears, this is your TomTom device, click on the disk to open it.
4. You will see a list of folders and a list of loose files
5. Delete all of the loose files. IMPORTANT: The folders with their content must NOT be deleted.
5. Close the window when all files are deleted by clicking on the [x].
Next we will reinstall the application via TomTom HOME.
1. Start TomTom HOME on your computer
• TomTom Home should automatically check for updates and prompt you to install them, if not:-
2. Click on 'Update my device'. If you get the message 'No Items Available', or there is not an application to download, click on 'Add Maps, Traffic, Voices etc -> Items on my computer', select the application and click on 'Add'.
3. Select the Application update.
4. Click on 'Device -> Disconnect Device', then turn off your device when it is done installing and disconnect it from your computer.
5. On a PC, in the System Tray by the computer clock, click on the 'Safely Remove Hardware' icon and disconnect the TomTom also in this way.
When switching on the device it should boot as normal again.
Nov 19, 2008 | Tomtom GO 720 GPS Receiver
Tomtom 100yds off
I have seen this when entering addresses with a letter in them such as 3N124. The address does not enter correctly you will get the wrong address and location. I am trying to find
out if the tomtom supports this address. So far I have been told, NO, by Tomtom support person, but have a hard time believing this since a Magellian accepts this and works. However I have seen a Magellian get my location wrong. I believe the map needs updating. Check the location by view route and zoom in on the location, does the address equal the location that is off if it does it is most likely the map is the problem. If the location equals the address entered maybe the sound is off, stop before entering your home and check the location vs your location on the map. Check you map year, also have someone else check with their gps, might help.
Oct 01, 2008 | Tomtom ONE GPS Receiver
How do i install my own maps into my tomtom go 720
The tomtom comes with a small memory card. you go to www.tomtom.com enter your tomtom card in the computer and download the maps to your memory card from the tomtom website.
Artgirl
Jul 18, 2008 | Tomtom GPS
TomTom password lost / forgoten
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 28, 2008 | Tomtom ONE GPS Receiver
Tomtom GO 720 GPS Receiver Logo
14 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
