Question about Dell 1707FPv Monitor
How to open the Dell 1707FPV flat monitor? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Lanhqua, If you visit youtube you can see video clips (8-12min) of some LCD monitors being disassembled for servicing/repair.... May I ask what you will do if u get inside your DELL 1707FPV???? Do you know what to look for? Bye for now. louie12fix on fixya or lmistyrel @ aol.com
Posted on Sep 25, 2009
My monitor dont want go on enymore. its like him have no power, bud power is i already try connect with other cable bud no result. wat i can do? or sombody knows the problem?
If you have a Dell Monitor it usually comes with an installer to make the Monitor run on your PC. Try too look for the driver installer and install it on your PC. If not, maybe your monitor is damaged or your video card is not compatible with your monitor or it is damaged. Try to see with this possible causes.
Feb 04, 2010 | Dell 1707FPv Monitor
I cant get the picture to turn with the screen
Your question doesn't make sense in English.
Oct 21, 2009 | Dell 1707FPv Monitor
My dell P2210t will only light up the top half of
it may be better to bring your LCD to where you bought to claim the warranty. don't try to open the LCD and try to fix it because you will lose the warranty.
Oct 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
The monitor shows 3 times under Device Manager. Is
check this link for explanation:
http://forum.soft32.com/windows/Multiple-Display-Adapters-Monitors-Device-Manager-ftopict354735.html
regarding the slow performance go to start-->run-->msconfig-->under services tab-->Check Hide All Microsoft Services then uncheck all unnecessary programs then click ok. under startup tab uncheck everything except the antivirus, wireless (if your using one) and other important program.
Jul 12, 2009 | Dell 1707FPv Monitor
1707FP MONITOR WON'T TURN ON. CHECKED ALL POWER SUPPLY, ALL OK. ON BUTTON WON'T DEPRESS
Generally this doesn't happen with Dell, I f you arn't using DLC or UPS there are chances of circuit break down in the display unit.
Jul 02, 2009 | Dell 1707FPv Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Dell Flat Screen Model 1907 FPt
Appears you have an inverter problem. Do you hear any sparking?
Mar 29, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Screen going off after 4 seconds
This is a typical LCD monitor problem. Here's a copy of my response to a similar issue /  post.
...If the power light stays on and the unit works even if for just a moment, then chances are that you either have a cold solder, or a heat problem with some components or your CCF Lamp is starting to fail.
All possibilities require that you open your LCD monitor and perform diagnostics of the components/circuitry inside. This of course would require that you be familiar with components, circuitry, soldering and the use of a VOM.
Cold solder - refers to soldered connections that have lost 100% of their connectivity. When the unit is jarred or after some time of use it looses completely its connection. The corrective measure require that the said cold solder be located and resoldered.
Heat problems with some components - the most often are power capacitors. These are can types rated something like 470uF/16V.  When power is applied and heat starts to build up, they start to looses their capacitance and therefore can no longer hold a charge.  Most cases, there are physical evidences such as blistering, brownish leakage at the top or at the bottom, swelling or gaps at the X/Y indentation at the top.
CCF Lamp - may involve the backlight or the inverter that powers it. A way to verify this is to shine a flashlight on the instance the screen blinks out at the screen. A faint image of your desktop should be visible.  The CCF Lamp is similar to household fluorescent lamp which of course can fail after some time of usage.  The inverter is a high frequency high voltage power for the lamp.
Since there are dangerous high voltages inside, extreme care should be practiced when working on exposed components.  Should you not be comfortable doing this, perhaps your best bet would be to seek the services of a qualified technician.
Hope this be of some help/idea. Pls post back how things are or should you need additional information.
Good luck and kind regards.
Oct 24, 2007 | Dell 1707FPv Monitor
Is there an easy way to open this monitor?
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t128460-easy_way_open_monitor
Dec 28, 2006 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 1707FPv Monitor Logo
392 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
