Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Flickering halo around each word of text and each object on the screen monitor is Viewsonic VP191b
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Petervzt, Gee wiz, I wonder how long they think these monitors will last?? Till 2019 I guess!!! Pete, if you don't have any expertise using a soldering pencil/iron , DVM, DMM, LCR meter and /or 30mhz oscilloscope then you will not be able to even attempt to repair this unit. The most likely failure will be in the "switch-mode-power-supply" and/or "inverter-supply" circuit. Check with Viewsonic for information on doing a SWAPOUT For cash+your old unit. you get a refurbished model with new CCFT's inverter board/SMPS. But that's only if they have a swapout prog. If you snoop around on fixya you should be able to find a place to get it fixed for less than a C note. I'm louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 25, 2009
Takes awhile for the monitor to turn on
This is common with this model. The switch mode power supply is not starting up when it is switched on. This supply creates 12VDC to operate the monitor. It could be the IC, a resistor or a capacitor in the start up circuit.
Monitor Miike
Apr 12, 2010 | ViewSonic VP191b 19" LCD Monitor
VP191b monitor no video Viewsonic
did you activate the monitor port?
Did you check theconnection?
Is themonitor pluged in the wall socket?
Jan 16, 2010 | Computers & Internet
I am getting a blue halo around text and objects on screen, wheb text is at the bottom the blue halo is curved over the original text.
A common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Or - your TV may have a convergence problem....
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 20, 2009 | Philips 51PW9363 51" Rear Projection...
Monitor (viewsonic VP191b)is completely Dead. Is there a fuse?
There may be one, but it wont look like a normal fuse. It could be a surface mount type or one that looks like a resistor.
If I had your monitor on my bench, I would first replace all of the electrolytic caps on the circuit boards. These are typical fail points.
Aug 09, 2009 | ViewSonic VP191B-H-B3 (Black) Flat Panel...
ViewSonic VP171b resolution problem
If you went from a standard screen to a wide-screen, you have to upgrade the video card.
Also, try going into the menu option on screen and have it automatically detect settings.
First thing you should do is update your drivers.
Should have said that first.
Jun 12, 2009 | ViewSonic VP191b 19" LCD Monitor
Viewsonic Monitor and the text is not black but grey.
try to log in safe mode and reinstall the display adaptors or uninstall them and reboot
Feb 01, 2009 | ViewSonic G90fb 19" CRT Monitor
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
Screen flickers
The problem is that it is on the verge of going out my mother had a monitor go out and it did the same thing. Also if you have any high frequeny things around your monitor thatr also migh be the thing. Try a magnet or demagnitze the screen if you have one on it.
Dec 04, 2006 | ViewSonic G810 21" CRT Monitor
Monitor Blanking
Buy a new monitor... It will make your eyes stop watering.
Sep 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
204 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
