Question about Motorola Mobility V360 Cellular Phone
Mxit problems on a samsung E250
My friend cannot download mxit on a samsung E250.She had it before and it worked fine but she deleted it and now she wants to download it again, but when she tries it downloads but you cant even open it because there is an error
Problem with the O2 Samsung SGH-E250 Cellular Phone Grant network access for mxit - network permission denied
Please check this problem with the service provider as the service is blocked to you.
you can call the toll free to confirm after giving the inputs required.
Sep 29, 2010 | O2 Samsung SGH-E250 Cellular Phone
Everytime I download mxit on my D900i it says java game error I even bought A different simcard but it still says the same thing
Java game error is an application error and not a hardware error. So replacing the SIM card will never fix this problem. There's a possibility that the Java version that you have in your phone is not supported by the MXIT.
Verify the supported Java versions of MXIT. Then check the version of Java you have in your phone.
Try to upgrade the Java in your phone, then try to download the MXIT again. If same problem occur, try to download another application, and if it DOES work, then there's no problem with the phone. There could be a problem with the application (mxit) that you are trying to download.
Contacting the manufacturer for additional info is a good thing to do as well.
Thank you and good luck!
Jul 10, 2010 | O2 Samsung SGH-E250 Cellular Phone
Samsung SGH-E250 cep telefonumu laptopuma bağlayıp telefonumdaki resimleri bilgisayara bağlamak için ne yapmam gerek?çünkü bunun için verilen CDyi...
Hi, i can`t go on mxit, it just say network permisson denied. Please grant network access to connect to mxit. Could you please help
Dec 16, 2009 | O2 Samsung SGH-E250 Cellular Phone
Cant login to mxit
Hi for some reason my PIN does not work anymore? the sime for this number i used on mxit is out of use for some time. I have been using this number from the start. What can I do to get logged on again?
Sep 09, 2009 | O2 Samsung SGH-E250 Cellular Phone
Can't download mxit
try *2767*3855# then try installing it again
Nov 02, 2008 | LG KG800 Cellular Phone
Mxit Problem
i downloaded mxit, set the GPRS several times but still cannot loggin on mxit
Dec 22, 2007 | Motorola Mobility V360 Cellular Phone
Samsung e250 limited service
this is a common problem with the e250. All you have to do it get a s/w upgrade for the phone from the nearest samsung customer service.
Nov 22, 2007 | Samsung SGH-D900 Cellular Phone
Motorola Mobility V360 Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
