Change carriage belt on hp psc500
How do i change carriage belt on hp psc500
2 Suggested Answers
713printech
  • 32 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Posted on Nov 19, 2008
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
Im looking for a printer caBLE FOR A HP PRINTER MODEL NUMBER PSC500 AND OPERATING DISC
You need a bi-directional, parallel, IEEE 1284-compliant printer cable with
1284-C connector. Here is an example from Tiger Direct:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=331719&CatId=76
You can download the software from Hp. Go here:
PSC500 Support
Select Software & Driver Downloads. On the next page select your opeating system.
Follow the directions. There is not a software download fro all OS. For instance, for XP you will use the XP OS to install drivers.
There are also links to manuals on the suppert page above.
Thanks for using Fixya.
Jul 06, 2009 | Computers & Internet
Carriage problem with grinding noise
Your printers carriage belt has gone loose you are required to change it. I'd advise you to send it to an expert because changing of a belt in your ink jet is not feasible with guidence through text messages.
Thankyou for using fixya free utility - Kindly rate my solution
Jun 27, 2009 | HP Deskjet 3845 InkJet Printer
Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
Since downloading a Microsoft update my HP PSC500 does not work
Try re-installing the driver or rolling back the driver and re-installing. maybe even check the manufacturers website for further updated drivers
May 07, 2009 | Office Equipment & Supplies
DesignJet 450C (E-size)
I replaced that belt about a year ago...it took a long time but seemed to go fine. I have a manual "carriage belt installation instructions" its 12 pages long. check out HP website and if you cant find it online, I could scan it for you.
Mike
mjlehto@charter.net
Mar 29, 2009 | HP DesignJet 450c InkJet Printer
HP 170 Color Copier Carriage Belt Replacement
My carriage belt has broke is there anyone who can repair it, or how can I fix it. H P Copier Model 170
Feb 04, 2009 | HP 180 Color Copier
Was printing ok, then the printer stopped and the two KY & MC icons are lit up alongside the lit up 'paper' icon. I have changed 3 cartridges just now and the lights still come up and the printer stops....
Is the print head moving at all?
Turn power off and see if you can gently move the printhead carriage or turn the carriage belt pulley on the left. If it moves freely without the carriage moving. Thats your problem.
There is a rubber mounted belt connector under the printhead carriage that often breaks when the slide is too dry from lack of lubrication.
I called hp to get the part. No part available. so I repaired the part with epoxy. Not an easy fix.
Jan 13, 2009 | HP OfficeJet Pro k550 Printer
Carriage belt replacement for HP 430
http://www.fixyourownprinter.com/forums/inkjet/36780
Fifth post down.
I changed the carriage belt using these instructions.
Hope that helps
Jan 08, 2009 | HP DesignJet 430 InkJet Printer
54 people viewed this question
k24674
jasbo
jasbo
