Question about Soyo SY-K7ADA Motherboard
I need the pin-out for the USB 3-4 and 5 ports on the Soyo SY-K7ADA V1.0
    Scholar:
  • 78 Answers
Here's the manual: http://www.motherboards.org/files/manuals/107/mk7ada12.pdf
Pages 5 and 29 give very detailed pinouts.
Essentially:
_ 4 3 2 1
10 9 8 7 6
-Jon
Posted on Sep 25, 2009
  • 44 Answers
There will be two rows of four pins (one will have 5 pins) each one of these is a bank of usb porst, it goes as such, away from pin five, 5V+, Data+, Data -, Ground, the 5th pin is for usb 3 so don't worry about
Posted on Sep 27, 2009
When i plucg in my external hard drive it tells me that is will run better on USB2.0 ports. I thought the USB ports on the Soyo P4VGA mo were 2.0. please help.
even if the port is usb 2.0 is posible that the cable is not usb 2.0,
advice:
install chipset driver of mpther board and check whit other miniusb cable and see if is the same problem
best regards
Sep 22, 2011 | Soyo SY-P4VGA Motherboard
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Need the layout of the USB plugs? 4pins in one row 5pins in second row.
Normal USB pinout is as follows:
1 VCC Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
Pin 5 is universally a second power, so it may not always be used.
Your motherboard may have the pin #1 marked but if not, standard is for the #1 pin to be closest to the CPU. Your manual should show this, if you have it.
Good Luck
Jan 07, 2010 | Soyo SY-P4I 845PE Motherboard
Soyo SY-P4I845GVISA Plus will not see USB keyboard
Go to the setup program and enable the "Legacy USB Support".
Nov 03, 2009 | Soyo SY-P4I 845PE Motherboard
I am trying to install SY-P4I 845PE motherboard into a case... need help with arranging the cables from my case to right pins on the motherboard
This board is a oldie...
Its going to be slow with the 3 ISA slots.
Anyway, most important is the 24 pin power connector and above to the right is a 4- pin video plug, which you must have to complete your video output.
Next, close to the CPU holder is a 3 - pin CPU fan connection.
Next, your IDE drives, you may want to check your pinout on the cables you are using.
Next, is the USB connections.
Sound, power on, turbo, reset and leds should all be together on one block.
Hope this has helped you.
Oct 03, 2009 | Soyo SY-P4I 845PE Motherboard
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Jan 22, 2009 | Soyo SY-P4I 845PE Motherboard
I need the manual for a soyo sy-kt400 dragon lite motherboard
Hi freebird2k6,
Go to this Soyo link:
http://www.soyousa.com/content/Downloads/155/&c=35&p=173&l=English
Drivers, bios & manual located on this site.
Manual is at the bottom of page. (Soyo no longer supports the board so download everything & burn it to CD).
Soyo may stop listing these drivers soon.
Mike
Dec 31, 2008 | Soyo SY-KT400D DRAGON Lite Motherboard
SOYO USB lock up must reset PC before accessing any USB
I have had alot of problems with soyo mobo's.  Seems the drivers that they provide for the USB are crappy.  Best stick with windows default drivers.
Nov 28, 2008 | Soyo P4VTE (SY-P4VTE) Motherboard
Soyo SY-K7ADA Motherboard Logo
202 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
