Question about Sony VAIO Digital Studio PCV-RX660 PC Desktop
Want to add memory card to sony pcv-v1/g
I have a sony pcv-v1/g for which I have just bought a 1gb RAM card. How do I get the back off? There are 2 tabs that you push up but it doesn't release. There are 4 screws in the underside of the base. Should I undo these?
  • bob_toze Sep 30, 2009
    Thanks a lot for the aadvice. I'll take another look in there. The computor is very small so maybe they are just hidden behind something
Easy! Tip the screen forward and you'll see a Phillips screw towards the top of each end of the lump that sits at the base of the back of the screen. Undo both of these THEN the 2 tabs you refer to can be pushed in the direction of the arrows and the whole top of 'the lump' then comes off. The memory is under the silver colored cover held down by 2 pieces of sticky tape(!). Remove tape. Remove cover. 2 slots are exposed. One has 512 in it. Put 512 in the other one! Easy!
Posted on Oct 19, 2009
Testimonial: "That's the best advice I've been offered. Thanks"
    Sergeant:
    Champion:
  • 289 Answers
You don't take the back off, you actually take the left side off (if you look at it from the front)
Posted on Sep 27, 2009
Testimonial: "That was helpful because it answerred my question but it didn't solve my problem. I still couldn't see where to install the memory."
  • Sean Blundy Sep 30, 2009
    it looks like a slot that is about 6 inches long and is right next to your processor
    they usually are colored white, yellow, green, blue, or black (mostly white and blue)
    they might be hidden behind your hard drive cords if your computer is small...
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
How do i upgrade the ram on sony vaio pcv-v1/g, please
Very easily! With the unit on it's stand, tip the screen forward as far as it goes (About 15deg past vertical). This uncovers 2 Philips cross-head screws, one on each end of the black box that hangs off the back of the screen and contains the memory,processor, fan etc. Now the top of the black box can be lifted off. Inside is an aluminum box with the lid taped (!) on. Remove lid, and inside are 2 memory slots. One will have a 500mb mem card in it. The other is empty. Fit you new 500mb in the empty slot for 1gb total (the max). Don't forget to use some form of anti static protection and of course unplug it from mains electricity before you start!
Jan 02, 2010 | Sony Computers & Internet
Can the graphics card on Sony pcv v1/g be upgraded
Are there any open sockets on the board? These would accomodate more video ram. If not, I'm afraid you may have to buy a new card. Are you replacing a card from the PCIe bus? If so, simply remove it and put in your new one. If you are working from onboard Video, you need to make sure of what kind of Video Bus you have, AGP ( older ) or PCIe.
Look in your manual for this information. All should be plug n play from here.
Oct 28, 2009 | Sony VAIO V1 (PCV-V1) PC Desktop
I want to add memory to my sony PCV-V1/G i have the memory and have removed the back where is the extra slot and how do I axcess it
it can be tough. ffirst where rubber gloves. Next make sure you are using the right memory. Then open the side o the machine. there are two light brown clips on either end. They will pull back on either end slowly and lightly. Then place you new memory chip in and press slowly untill both end clip back into place.
Oct 09, 2009 | Sony VAIO Digital Studio PCV-RX660 PC...
How do i fit extra ram in this all in one pc/media center Sony PCV-V1G it is impossible to gain access to the inner workings?
every computer case has an opening and if your motherboard has more slots for ram than one you can buy one for *********** board but make shure it is the same as the one you already have in it.
Sep 26, 2009 | Sony VAIO V1 (PCV-V1) PC Desktop
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
What kind of memory does the Sony Vaio PCV -7744 use?
From the model number you were asking about it says that it takes pc2700 ddr333 RAM It has 256MB standard and is upgradable to 1GB between the two sockets for RAM. Thanks
Mar 17, 2009 | Computers & Internet
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Memory upgrade
just by the ram from the market first u have to know type of ram
thir is many kind of ram coming so now a days most of ram coming ddr other on 0is ddr2 which is ur ram bye the then after open your cpu cabinet & then after find the ram slot in your pc then after replce the ram
have good day
Feb 15, 2008 | Sony VAIO V1 (PCV-V1) PC Desktop
Sony VAIO Digital Studio PCV-RX660 PC Desktop Logo
514 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
