Question about Air Tools & Compressors
It has been purging alot the last couple of days
I have a arrow a200-2 refrigerated air dryer and it has been purging alot the last couple of days about every 5 minutes or so got any ideas of what it could be
  • 41 Answers
There is a timer which control the opening and closing of the said valve, check this timer,or if it is in tha integrated circuit check the setting ,if problem not solve disconnect the valve from the timer , and add add a seperate timer and connect it to a power supply
Posted on Sep 29, 2009
Our air conditioner keeps going off, and won't come back on, what is the problem?
does the dryer still wor? you can try switching off the circuit breaker then back on in case the ac is locked out electricaly. do both the dryer and the ac breakers, but this would not be common to two circuits which should be independent.
Apr 22, 2015 | Heating & Cooling
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Cool tech 34788 purges alot. Excessive purge time and set error messages for being unable to purge.
Please check 1# The refrigerant which you'v add to the machine, it may CONTAMINATE or NOT PURE R134a. the machine will purge continue while active VACUUM mode if refrigerant is not origenal ! Identify refrigerant if possible.2# Check the automatic air purge device & air purge solenoid repair or rebuild as require
Jul 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34788 "air purge not working"
Please check ISV tank air purge (pressure) transducer & 12V DC discrete Solenoid ( both lacated on top of ISV ), it sounds like defective!
NOTE: Never use Automatic Mode till you are not very familiar with this machine
Jul 06, 2010 | Robinair Cool Tech 34700Z Recovery,...
Ice maker will not work I just changed filter
if it worked b4, make sure the filter flow is ried direction, also, make sure water is on and check maker switch or lever , to see if it is on position
Jun 12, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The purge light is blinking on the honeywell box on my ac box in house.its been draining alot of water from the pipe that leads out side.been doing this 4-5 days.is this normal?
If the ac is cooling you will get a lot of water out of the drain as much as 17 gallons a day. The purge light blinks on some of the Honeywell board when all zones call for cool or heat. Russ
Jul 18, 2009 | Heating & Cooling
Dryer vibrating alot and making alot of noise.
check the felt around the inside of the door to see if it needs to be replaced
Apr 23, 2009 | Dryers
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Air Tools & Compressors Logo
21 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
