Picture looks really cloudy on my 43pp920217, is this something I can fix myself
  • 3,459 Answers
Cloudy screen
It's possible that you have moisture on the inside of your camera, causing the sensor to fog up. It is also possible that you have fog on your lens as well. I have had cloudy images with my Nikon when it fogged up inside. The best thing to do is to make sure it dries out. This usually solves itself so long as you are in a dry location, but if not I would take your camera to a local repair shop to have it looked at and fixed. It really does sound like a moisture issue however. Do NOT dry your camera using heat or anything! If it doesn't dry on it's own, take it to a pro to get it fixed.
Jul 09, 2013 | Nikon Cameras
My TV looks really badly cloudy and the color is a little bit reddish orange. Does that mean I have to get the coolant for the bulbs or something and is it something fairly easy to do? Also the power...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2011 | Philips 55PW9363 55" Rear Projection...
Cloudy picture
NO, IF YOU SPILL ANY OF THE FLUID ON THE BOARDS THEY ARE RUINED AND ALSO IF YOU DO IT INCORRECTLY THEN YOU WILL HAVE TO RECONVERGE THE ENTIRE SET AND THIS TAKES A LOT OF TIME AND SKILL.
Sep 14, 2009 | Televison & Video
Picture is cloudy i go to the setup and sports, media, etc all are terrible any ideas
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I jhad was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
Mike
Aug 08, 2009 | Philips 60PW9363 60" Rear Projection...
Same issue: PICTURE IS HALF THERE- WHAT TO REPLACE?
Any takers for a Class Action Law Suit against LG and report to Consumer Affairs?
Jun 30, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Cloudy Picture
can you psot a pic of what the picture looks like. I should be able to diagnose it if I can see the image and what its doing.
Apr 04, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Phillips 43pp920217
On these sets, if your not experienced with this problem I would not try, but you could get the the part yourself and replace it. Call PTS 1800-844-7871 and ask to speak to a tech and he or she could tell you what you need and how to put it in. I just repaired a 51pp9202h/17 and would not want to do another. It has many boards in it and depending on the problem you could only buy another board and replace. Mine went black, I could hear audio but no picture. Thought it was the convergence board but it was the SSB the one with the Flyback on it. So after replacing almost everything I just bought another and its fixed now. So hope this helps
Sep 13, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
