Question about Video Game Consoles & Games
NEED DRIVER FOR MEDION JOYSTICK JOYPAD COMBO 9604
Mutimedia driver need
http://download.cnet.com/%7Bvalue=http://www.download.com/jetway-motherboard-driver/3000-2098_4-163033.html or http://download.cnet.com/%7Bvalue=http://www.download.com/motherboard-driver-audio-via/3000-2110_4-130898.html This package supports the following driver models:
  • Vinyl AC'97 Codec Combo Driver (WDM)
  • VIA AC'97 Enhanced Audio controller
  • VIA Sound System
  • VIA internal FM Synthesis
  • VIA PCI Audio controller
  • VIA MIDI External Port
  • VIA Gameport Joystick
Hope this helps.
Jan 16, 2013 | ASUS Computers & Internet
I have a USB vibration Joystick. But i lost my Driver floppy, now i cant use the many features ...
Check the exact model of your joypad and try to google it or go to the official website of the product.
Oct 04, 2010 | Video Game Consoles & Games
My phone keeps selecting the ok/select button
Dear,if ur joystick is working properly then u just need to change its keypad and its keypad are cheap,and if ur joystick is also irretating u then after disassemble ur fone and remove keypad and joypad as well then put 2 to 3 drops of petrol into joypad then up ,down ,left , right and round ur joypad untill petrol drys.thanx
Mar 09, 2010 | Sony Ericsson K800i Cellular Phone
I want to know will a Logitech Attack 3 Joystick work on need for speed underground 2 or can you even use joysticks fos racing games
ya the joystick will work you can use it because am also having the same am using it , its perfect but you have change control options in the game to joystick control and also if you want you can the options as you like, but this kind of joy is mainly used for flight running games but it also works for all joypad control games too.
Oct 22, 2009 | Logitech Attack 3 Joystick
Keyboard don't work in my Fifa 09 game
You have to set the controls on the options or settings list within the game. Make sure keyboard is selected and not JoyPad or JoyStick or something. See if that works.
Apr 06, 2009 | Video Game Consoles & Games
Joypad
Try plugging the joystick into the opposite port - if it is on the Player 2 port, plug it into Player 1, etc. If it works in one port, but not theother, then one of the ports is bad/damaged. If it doesn't work in either port, it is the joystick itself. Replacement joysticks can be ordered from VTech, Amazon, Target or Walmart.
Other troubleshooting methods:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Oct 21, 2008 | Vtech V.Smile TV Learning System
Joystick psp prooblem
That it is probably an hardware fault, the joystick switch stay stuck as you are pointing up.
If it happens again get a replacement joystick.
If you are still under guaranty and that happens again, call them and ask a replacement joypad, tell them you get the problem from time to time.
good luck.
Sep 11, 2008 | Sony PlayStation Portable (PSP) Console
Freedom 2.4 problem
What you can try is to press the surface on the receiver where the light blinks. This is actually a button you can click. The blinking pattern should then change. Now press any button on your joystick. The receiver is now scanning all channels for input and it should pick up the joystick's signal.
Most wireless devices from Logitech have multiple channels, which you can switch between, but this also means the receiver can be set to channel A and the joystick to channel B, which means they are not matching up.
After the click on any of the joystick buttons the light on the receiver should change to continuous light instead of blinking, indicating the link has been established.
You can find this solution on the Logitech web-site as well. Select your joystick and under the support steps it should say 'For wireless products you should now reestablish the connection following the steps here.' Where the word here is a hyperlink.
There you will find out that the receiver has a button to trigger the channel.
Sep 10, 2008 | Sony Logitech Freedom (vs9632830403)...
Not working help
joypad doesn`t work well ob fifa 09
Jan 19, 2008 | Saitek ST290 Joystick
Video Game Consoles & Games Logo
446 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
