Question about Olympia Mastertype 3 Typewriter
It skips every 13t5h space. How can I change this
It skips every 13th space. It types 12 characters, and skips one. It keeps on repeating this pattern. How can I change this setting?
  • 11,896 Answers
What make and model is this?
Posted on Sep 25, 2009
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Olympia supertype 330 types wrong characters
check the pitch setting to make sure that it matches the printwheel. It is the switch that is marked 10, 12, 15, PS. PS is proportional spacing and will only type correctly with a PS wheel. The number settings are for PICA ELITE and MICRO.. 10, 12 and 15. The numbers are characters per inch...so the larger the number, the smaller the character.. it is the opposite of FONT SIZE.
Feb 05, 2009 | Olympia Supertype 330 Typewriter
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
10 pt printwheel printing 12 pt spacing
Some type styles do have thinner print than others. The pitch is automaticly selected when you change printwheels. You can measure the pitch by printing 12 letter "i" and putting a ruler up to it.
12 spaces per inch is elite and 10 is pica.
Nov 19, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lettera 22 - sips and adds spaces on occassion
If it skips at the same place or skips every 10 or 12 spaces all the time it is a broken tooth on the escapement wheel or rack. It could be in typing you are lingering on the key causing it to spring back a little ans space over.
Apr 18, 2008 | Olivetti Lettera 25 Typewriter
Skipping parts of the letters
If the ribbon isn't moving a full space for each letter printed try code . or , this changes yhe spacing.
DickyO
Feb 19, 2008 | Nakajima AE-740 Typewriter
Character spacing
Joany, look for a function,usually on the left side of the keyboard on the IBM,that has the markings 10,12 and 15. And if my memory is correct,there will be a series of lamps which light up at the selected pitch. I would look for a key marked "pitch" and press that. Good luck.
Nov 21, 2007 | Lexmark Wheelwriter 1000 Typewriter
Olympia Mastertype 3 Typewriter Logo
35 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
