Question about Canon i9100 InkJet Photo Printer
I have i9100 printer...which has waste ink tank almost full...can only print by pushing resume button. How do I get to tank to clean pad?
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA IP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
On http://www.neilslade.com/Papers/inkjetstuff11.html you can find how to manually clean the waste ink pad.
Another useful site:
http://www.cyber-ink.com/member-canon.html
Posted on Sep 25, 2009
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
Sep 04, 2008 | Canon Office Equipment & Supplies
The waste ink well is full
Reset Procedures for Canon i560 Printers
  1. Turn off i560 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
  9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon BubbleJet i560 InkJet Printer
Waste Ink Tank is full and printer will no longer work. How do I repair this problem?
I wouldn't override that error message. Best bet is to open up the printer and give it a good cleaning. If you're unfamiliar or not comfortable with the procedure, take it to your closest computer repair store to have it serviced.
May 12, 2009 | Canon i9100D (Bundle) Photo Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Waste ink absorber is full
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Nov 19, 2008 | Canon S200X Ink-Jet InkJet Printer
Canon s400 doesnt print only blinks eight times
The tank is situated on the RHS.
The Print Head rests there when not in use.
Open the flap to expose the Print Head,slide the Print head across to the left.
On the area where the Print head rests, there is a black plastic square of plastic which contains 2 narrow vertically positioned ink pads.This is also spring loaded.from underneath.
The pad on the left is for BLACK the other Color.
These become saturated with ink during the cleaning process.
I suspect the Print Head has a built in sensor to detect overloaded waste tank.
The pad can be removed this by hooking it out, sideways.
Unless the pads are leaking ink everywhere I wouldn't remove it.
Use Cotton Buds to soak up the excess ink. I used about 15.
Then.....
Turn off printer
Hold down RESUME button and press POWER button.
Keep holding down POWER button and release RESUME button.
Press RESUME button 2 times, then release BOTH buttons.
The GREEN light will flash and stop flashing.
When the GREEN light goes out, press the RESUME button 4 times.
Press the POWER button and the printer should turn OFF
If not press the POWER button once more.
My experience was when turning the printer on at a later date the POWER and RESUME lights still flashed.
All I did was press the RESUME button and the printer operated as normal.
Jan 06, 2008 | Canon S400 InkJet Printer
Waste tank full
Inkjet pads are between the printer chassis and the bottom of the printer case. Typically a large felt pad.
My Canon i9100 has eight orange flashes and indicates on screen "waste ink tank is full". After opening up mine I found this to be false, only one third soiled. This then leads me to believe the i9100 has a timer to go off after a preset number of hours.
Anyone know how to reset the "full waste ink tank" error?
Dec 08, 2007 | Canon i9100D (Bundle) Photo Printer
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
One of the ink tanks is empty. Replace it.
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Canon i9100 InkJet Photo Printer Logo
117 people viewed this question
old marine
old marine
