Question about Whirlpool Refrigerators
Manual for CBI8M/Ic/FAN - Whirlpool Refrigerators
Salve volevo una informazione ho acquistato un frigorifero da incasso diversi anni fa ma ultimamente siccome va e viene la corrente in casa mia il frigorifero si e scongelato il tutto anche dopo la corrente sia ritornata , ho chiamato un tecnico e mi ha riferito che il funzionamento e corretto cio? questo modello e cos? quindi devo staccare la corrente e aspettare circa 15 minuti ma e normale??
Posted on Jan 10, 2015
Ic-7600 fan workin frequently
its keeping the finals cool, its doing its job
Feb 26, 2014 | Icom IC-7600 HF/6 Transceiver
No light and no fan Circuit Breaker not blown out. Any advise
An open thermal fuse inside the fan winding will cause it. Thermal fuse blown if the temperature reach beyond it's temp rating. That is common in a manual control electric fan.
If your fan is electronic control, a blown fuse inside will also cause that, no power, no light. A defective micro-controller IC and crystal oscillator will also cause that trouble.
Have it check by a service technician because it's not for DIY job.
I hope I give you idea regarding your fan trouble.
Jun 26, 2011 | Casa Vieja Sedona Golden Bronze Fan
My SC-HT650 system reads F61. I think I need a new transformer. Where do I find that?
Not the transformer. probably needs a voltage ic or output ic. F61 is a voltage error code. if it was the power tranformer it would not power up at all. It also could be just a bad fan. The fan should start as soon as you turn it on.
Jan 26, 2011 | Panasonic SC-HT650 System
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
I can't get my furnace fan to stop running-even in the off position
Your thermostat has AUTO and MANUAL for fan Make sure it is set for AUTO. If it is set for AUTO and the heat is off and cooled down AND the fan still runs then that will be a bad relay. If yours is newer then the board will need to be replaced. If yours is an older model you may need to replace the fan and limit switch8fe474e.jpgThis mechanical switch works on rise in plenum temp. It turns on the fan a around 110 f and it shuts down the fan at 90f. Newer furnaces use timers and relay on the IC board.
Oct 26, 2010 | Heating & Cooling
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
KENMORE 79577579600 REF. with an error code er-1f the manual said " poor bldc connection, drive IC , and TR. checked the connection and its fine but WHAT IS THE DRIVE IC AND TR? if I unplug the fridge and...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^$#%
Jun 13, 2009 | LG LRFD25850 French Door Refrigerator
F61
check the fan
If one fan dosent work it will show the error F61
May 15, 2008 | Panasonic SC-HT940 System
Error F61
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Dec 05, 2007 | Samsung HT-DS610 System
Refrigerators Logo
617 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
