Question about Panasonic KX-P1150 Matrix Printer
I have the printer plugged into the computer and turned on but when I print a document the computer is not offering the Panasonic as a print option
2 Suggested Answers
SOURCE: Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Posted on Nov 12, 2008
Idem didn't come with manual, need instuctions.
If you have the adobe reader on your computer, you can access the .pdf version at this link here http://www.appliancefactoryparts.com/dehumidifiers/delonghi/de500p.html. Adobe offers a print option for documents so you can print it out if your printer is ready
Sep 03, 2013 | DeLonghi DE500P Dehumidifier
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Printing VERY slow for PDF documents on DP-8045
well if you really needed a pdf printing concern, you may add an option which is Multi Page Description Language Controller Module. the post script printing language will be activated and you won't have to wait for the computer to process the pdf document on a gdi format (microsoft). what's more is that your mac computer can also directly print to the dp-8045.
that's it
Apr 30, 2010 | Panasonic DP-8045 Grayscale Copier
How to cancel a print order
use the control panel on your computer, pick the printers, double click on your printer and it should list documents currently in Q. Highlight the print jub and pick the documnent ta b at the top left of the window and pick cancel.
Nov 03, 2009 | HP DeskJet 3650 InkJet Printer
Stuck on "all photos option
Have you tried -- turn off machine PULL out power cord from printer  and USB connection wait 2 minutes then plug it back in Check your print dialogue box to make sure you have no pending documents from computer
Apr 23, 2009 | HP PhotoSmart P1000 InkJet Printer
Printer printing documents again when computer restarted
go to the "computer" place at the start
then go to printer, or do whatever u have to do to go to printer
then click the button or icon
it should show the documents names
click it and press delete
there
Mar 05, 2009 | HP LaserJet 1012 Printer
Booklet printing
You're right, most do offer that option from the print driver. I would check Panasonic's web site to see if they offer a postscript driver, that may have booklet printing.
Jun 12, 2008 | Panasonic Workio DP-2330 Printer
Will not print after turning printer off
I used to have that same problem what i suggest doing is restarting not only the printer but your computer aswell. That seemed to solve the problem for me
Oct 15, 2007 | HP LaserJet 1020 Printer
Panasonic KX-P1150 Matrix Printer Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
