Question about TT Systems PMP3850 Mate 2.4GHz Phone (PMP-3850TT)
Phone stop working.
My phone will not charge my brand is PMP-3955 2.4 GHZ DSST PHONE MATE. I THANK I NEED A NEW BATTERY.
0 characters
1 Points
Brand new phone, will not charge. have plugged it in. batteries test out ok. however it looks like the base units are not picking up the charge. brand new phone. trying to use it in bangalore india where...
Take it back to where you got it and demand a replacement. Usually I stay far away from extended warranties but in the case of telephones I make an exception. They are made very cheap these days and don't last very long.
Aug 20, 2011 | Panasonic KX TG4053 19 GHz Trio Cordless...
I have a CTP8600 Cordless phone made by Coby in 2003. The battery pack for the handset is apparently no longer charging. Coby has stopped making (or supporting) this product. I would like to replace the...
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
May 20, 2011 | Coby CT-P8600 Cordless Phone (CTP8600)
Switch the phone off at the Mains 5 mins,
Re-register the phones to the base unit.
Your manual will show you how.
Should be good then.
Jan 06, 2009 | Uniden TRU9585-2 5.8 GHz Twin 1-Line...
Without getting too involved,I simply dissassembled entire storage bin and to my surprise found cover obscured by other stuff,and in new condition as the rest of phone of which I reactivated last night.The original battery took the charge in no time which really surprised me as well.Thanks,stan.
Jan 06, 2009 | TT Systems PMP3850 Mate 2.4GHz Phone...
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at or eBay.
Jun 22, 2008 | Vtech 9009111 Cordless Phone
Owners manual for American Standard electronic bible model EB-1
I still have my original Owners Manual. How can I get A copy to you?
Thanks, James
Jan 15, 2008 | Columbia Telecommunications Group Ctd-201...
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
PhoneMate PMP-3850BK 2.4 GHz Analog Cordless
Does the screen of the handset come on when it is off of the base, and you press power/call? If the handset can lightup, or the screen comes on, then the line cord from the jack to the base is not in correctly or all the way. Or, you handset and base are not synced together.
May 22, 2007 | Casio PMP-3850BK Cordless Phone
"Low Battery"
Phone starts to beep after ten minutes or so then goes dead. Is there a way to change battery
Aug 25, 2006 | Uniden Cordless Phone exai398i
TT Systems PMP3850 Mate 2.4GHz Phone (PMP-3850TT) Logo
19 people viewed this question
Top TT Systems Phones Experts
Are you a TT Systems Phone Expert? Answer questions, earn points and help others
