Need to press power several times on my Compaq laptop to power up
I need to press power several times to power up. My Compaq laptop tries powering up and shuts itself on and off before the screen displays anything. After I press POWER a few times, it finally comes on and works fine.
  • 37 Answers
Your power button is worn out! You might need to replace the keyboard. Only is you power button is connected the the keyboard assembly.
Good luck,
Robert
Posted on Oct 12, 2009
  • 50 Answers
I had a comparable issue with my Laptop too and it was happening because of the memories, so I had to reattach them.
Since I did it my laptop is working fine.
I hope it help you.
Posted on Sep 25, 2009
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
My asus laptop's power button need to press several times to start...plz help
Mabie power buton is broken or else.... but i need to know what is your asus pc model...
Jul 09, 2012 | ASUS Computers & Internet
When i press the power button on the nw8440 the charging light just flick several times but it does not start
Chances are, you have a bad motherboard. You can try one thing. In my experience, it works about 10% of the time.
Unplug the power cable from the laptop. Remove the battery. Press and hold the Power button on the laptop for 30 seconds (This will drain the power from all components). Put the battery back in the laptop. Connect the power cable. Try to turn it on. Again, in my experience, it works seldomly (I promise I've seen it work several times, though).
If that doesn't correct your issue, you may have a DC jack which has solder joints broken. If your laptop charges "sometimes" but not others, this is probably you. The DC Jack is the component inside of your laptop which the power cable plugs into. Over time, whether you do as much as trip over the cable down to just laying the laptop on your bed (it will sink down and put pressure on the DC jack/power cable), the DC jack may have wiggles itself free of the solder joints holding it to the motherboard. This is not a cheap repair.You can test this by giving SLIGHT upward pressure to the power cable at about an inch away from the edge of the computer. Keep an eye on the front LEDs. If no other LEDs light up, then you probably have a bad power cable. If, when gently pressing up on the power cable, you get an LED to turn ON, then you have a bad DC jack.
In either case, the only fix is to take the PC to a computer repair shop.
I hope this helps and thank you for using Fixya.com.
Sep 22, 2011 | HP Compaq nw8440 Notebook
Compaq NX6310. Wont power up. When I press silver ON button the orange LED on front flashes 7 times ...And nothing more. I am measuring 19volts on power adaptor on the inside and outside surfaces of the...
check for damaged usb ports, this can often cause this problem. if you find distorted contacts within the usb port, try to straighten them or isolate them. hope this helps.
Apr 27, 2011 | HP Compaq nx6310 Notebook
Hp compaq 6720 laptop, wont charge battery, bought new battery have same problem. have tried several different chargers and they are all working, but not charging battery
If the notebook does not charge even after replacing it with new battery and checking with several chargers then it is laptop power jack issue.
You may need to replace it. However to confirm the issue is with power jack just remove the battery and try to power on the notebook only with AC adapter. If it does not then it is the power jack which is allowing the ac power to be charged.
If your notebook is in warranty then you can ship it to HP and if it is out of warranty then check the link below, you can purchase the power jack of the laptop from here.
http://www.laptopjacks.com/parts/HP-6720s-laptop-parts-466.html
May 27, 2010 | HP Compaq 6720s Notebook
My Hp Compaq 6820s don't start when I press power button.
This simply means that the battery is dead. Pull the battery out and try to start it again (with the power adapter plugged in obviously). If it starts up, you need a new battery, if it does not start up you may have a bad power adapter or broken power jack.
Feb 26, 2010 | HP Compaq 6820s Notebook
My Compaq F750US won't turn on
There is a very good chance that your cpu got too hot and, has died. replace the cpu. you should be able to remove it with only a blade screwdriver.
e-bay sells replacements and, the manual for your computer and, instructions can be found at: HP.com
Jan 24, 2010 | HP Compaq Presario F750US
Compaq F572US won't start (led turns on, but nothing happens)
I have been having the same problem. At first I thought that the motherboard was fried and the laptop was a paper weight, but I kept it plugged in and kept pressing the power button several times over the days. It would always seem to start (screen remained off/black) and then it would just go off again in seconds. But persevarence has paid off, finally almost after a week it started up like normal and started working again as normal. I then had the same episode repeat a few weeks later, the computer was useless for a few days and again started up as I kept pressing the power button several times a day.
I believe the problem is with the standby mode. Each time the problem happened, it seems like the computer was going into standby mode and the power button was pressed again before it could competely go into standby or the button was pressed again while it was coming out of standby.
To sum it up, nothing is wrong with the cimputer components, there is some problem with the standby routine. Keep pressing the power button and hopefully you can get lucky in getting the computer to start again. Long term, I am thinking about checking whether there was a new flash update that came out that could fix this problem. I purchased the laptop compaq F72US in 2008 and never updated anything. Also worth noting that I called HP and they didn't stand behind their product.
Sep 28, 2009 | Compaq Presario F572US Notebook PC
Compaq doesnt power up at all
try removing the memory and clean it, if you have more that 1 put hem back 1 at a time turning the laptop on each time
keep us informed
regards
Nov 24, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
