Question about Roper Washing Machines
Will not spin with towels
  • 34 Answers
You belt has probably burned up or slipped off = at the bottom of the machine
Posted on Sep 25, 2009
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
Stop Kenmore 700 series top loader from ripping small holes in towels?
Look for damaged rotor, possibly small dents with sharp edges or cracked unit that catches the clothes.
Feb 17, 2015 | Kenmore Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Washer doesn't spin well, some clothes and towels comes out wet.
either it's your belt needs replacement, or your heating element is bad. anyone there mechanically inclined?
Nov 26, 2009 | Washing Machines
Whirlpool top load wash machine does not spin
Check your lid switch it may be bad.
Mar 18, 2009 | Washing Machines
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Samsung, rossby washing machine
There is a capacitor linked to your motor by wiring.. That capacitor is most likely the fault... It is normally a 400vac 12UF(J) capacitor
Jul 10, 2008 | Samsung Washing Machines
Washing Machines Logo
19 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
