Question about Onkyo TX-DS575 Receiver
Onkyo TX-DS575 turns off after about 10 min.
I have this reciever and has been awsome, but now it will only play for 10-20 minutes then just turns off. The amp gets extremely hot but still plays everything fine. It seems like it may be the power supply failing but I really don't know. So if you can help me, thanks!!!!
  • 752 Answers
It could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Posted on Dec 18, 2007
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
The amp plays fine for about 15 to 20 minutes, then an extremely loud, over powering hum/buzz takes over, and then the amp has to be turned off, but the problem persists. I've tried several guitars,...
You say the "tubes are fine" I take it that you have either replaced them with new or used a very sophisticated tester on them. A heater-cathode short might cause the symptom. There are a bunch of tests I would want you to run alnd get back to me with the results.
Heat up the amp but DO NOT play anything into it for the usual failure time or more and they start to play i... did hum occur WITHOUT playing? With all volume controls down does the hum occur?
The right tools is an oscilloscpe to fing out if the filter caps are good. These are C31, C33, C35, C36.
With hum present in failed stater, plug in a grounded plug into the power amp in jack... if hum is stiil there, check the +/- 16 volts regulating Zener for ripple. get schematic here:
Jan 29, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Amp kicks off after a few minutes of play. It will play again after a few minutes, but then kicks off again.
My best guess is that your over loading the amp. Check and see if the amp is hot when it cuts off. Most amps have a "safety" cutoff that will shut it off if it get to hot
Oct 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
Amp works on off on off
The buzzing is possibly the electrical mains hum at 50hz, all amps have a hum/buzzing... if you have to tap the jack lead between the guitar and amp it could simply be a connection problem, the cable may be old and internally damages, maybe loose wiring on the other side of one of the input jacks
Jay.D Bsc Music Technology
SEO - Web business optimisation and online promotion
Dec 13, 2007 | Audio Players & Recorders
Sony MEX-1GP getting warm
It's common for head units to run extremely hot when driving all 4 channels from the internal amplifier. If you can get some air flowing over the heatsink, it will help greatly. The smallest fan you can find will move enough air to reduce the temperature significantly (assuming it's placed where it can be effective).
A better option would be to use an external amplifier.
Dec 09, 2007 | Car Audio & Video
My car AMP will play for a few minutes, then just Turn OFF
Is your sub single voice coil or dual? If it's dual, is it wired in paralel or series? It's possible for an amp the heat up so fast, the outside is not hot to the touch. Also, the next time it happens, use a paperclip and short the 12+ to the remote wire on the amp and see if it comes on. Let me know, and be sure to leave feedback or I don't get paid
Sep 30, 2007 | Car Audio & Video
Boss 2500d gets hot and trips off and on every 5 mins...
If you are bridging the amp then you must DOUBLE the "ohms load" that is specified. I.E. If you need 4ohms per channel, then when bridged you would need 8ohms per bridged channel. If your load is indeed correct then you have a fried output probably. Try to run it without any speakers on it. If it still gets hot then you for sure have a fried amp. All the symptoms you decribe sound just like you have too much of an "ohms load" though.
Aug 01, 2007 | Boss Riot 2500D Car Audio Amplifier
Onkyo TX-DS575 Receiver Logo
171 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
