Question about Emerson LC320EM9 32 in. LCD HDTV
One of the channel shakes - Emerson LC320EM9 32 in. LCD HDTV
Why are my channels either unobtainable or breaking up ?undefined
Freeview has gone through a shake-up. There was another major nationwide retune that happened on Sept 3rd. If you haven't yet retuned then now is the time.
You need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 10, 2014 | Televison & Video
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
I have a Sony KV-27XBR55 TV, that wont display signal (Video nor sound) it only displays 0 0000 on the Channel input
It sounds like you are in the service menu---aside from the zeros what if anything else can be seen?
The set does have (all Sony sets do) a reset done only with the original Sony remote.
Dec 21, 2012 | Televison & Video
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
Shaking yellow screen
Well a yellow screen means that you have a bad capacitor inside of the console.
Apr 13, 2012 | Nintendo NES Console
When tweaking the motion settings low makes everything jitter really bad and high is a bit better. Even at custom 10/10 it still jitters enough to annoy me. Is it a defective tv? The strange part is...
Try checking the Hz settings on each channel you use. It may be that what you happen to put a setting on is only effective on that channel. Which means if you had to originally set it for 60 or 120hz on the hdmi channel, then you may have to do the same for your tv/satellite channel.
Jan 13, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
When driving over rough ground my midland alan 48 plus multi cb will sometmes change channel on its own i wondered if this could be a mike problem as you can change channel from the mike
Check for loose buttons, could be something loose inside, if its changing on its own when its moving around could be from vibration that something has come loose.
When parked just try shaking the mic first if that doesnt do it shake the cb itself and see if the problem persists
May 18, 2010 | Midland Radio Communications
TV picture is shaking up and down.
Try unplugging any devices near the TV one by one and see if that helps.
I had the same problem with my picture shaking on all HD channels and found that it was my land line phone interfering with the signal.
Hope that helps!
Dec 11, 2009 | Samsung LN46B640 LCD TV
Bass/Treble balance on Bose Lifestyle 5
You need to go into your menu and set the "MOVIE EQ" to your liking. That is where your bass/treble balance is on a Lifestyle system.
Mar 01, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Emerson LC320EM9 32 in. LCD HDTV Logo
27 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
