Question about Samsung Jet S8000 Cell Phone
How do i turn on voice recognition on my samsung jet
Tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
How can I disable VoiceOver?
Return to the initial set up procedure and disable it.
Jan 15, 2016 | Samsung UN50HU6950 50 4K Ultra HD 120Hz...
Audi voice recoGnition
There are certain times it won't let you use voice recognition, like when you're backing up or before the system has initialized (takes about 20 seconds after you start the car. Have you tried it outside of these instances?
Mar 24, 2014 | 2007 Audi S6 Sedan
Hi, how doi turn the voice mail off on my samsung jet?
Contact your carrier and have them disable the mailbox. They should also be able to disable or tell you how to disable the forwarding.
Apr 24, 2011 | Samsung Jet S8000 Cell Phone
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
Voice Tags
Go to www.gsmarena.com and select Samsung and your phone. Read its specifications and if that does not answer your question then read its reviews there which will definitely provide an answer.
May 09, 2009 | Lands Phones
Setting up voice recognition on my 920t
voice recognition should be set up by default on the unit you describe. in order for it to go into voice recognition ou need to do navigate to the spoken address
Dec 27, 2008 | Tomtom GO 720 GPS Receiver
Inspiron 1420 - I cant hear my own voice, but a guys voice.
Go to Speech Tool Bar, then Select "Speech Tools, then Speech dialogue box will open, Select tab "Speech Recognition".
Create a new Recognition Profile, then delete old profile
Dec 02, 2008 | Dell Computers & Internet
Razr Problem
check if the voice recognition button did not get stuck and is connecting.
Jun 28, 2007 | Motorola Mobility RAZR V3
Samsung Jet S8000  Cell Phone Logo
272 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
