HP Officejet Pro 8000 wireless. Diagnostics
Diagnostics summary say's: Printer Settings Consistent with wireless router settings= FAIL . I just got a new router and modem, how do I get it set up so I can use it wireless from my laptop again?
usopm
  • 33 Answers
SOURCE: HP Officejet Pro 8000 Printer goes through motion
your pint head dirty. so pls clean with wet close. if not work try soak with warm water until all dry ink gone pls be carefull when you do that make sure your print head dry before you use again.
Posted on Aug 10, 2009
SOURCE: HP Officejet Pro 8000. Spooling? Printing badly.
Check the following link which will be help for finding out the solution
dentify the specific printing problem
To change the priority of the Spooler service, open the RegEdit32 application and change the value of the PriorityClass of type REG_DWORD in the following key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\ Control\Print
Set that value to the priority class required. A value of 0, or no value entered, is substituted with the default value of a background process of 7 for Windows NT Workstation. (For Windows NT Server background processes, take a value of 9.)
Posted on Jan 04, 2010
  • 569 Answers
SOURCE: everything prints crooked on HP Officejet Pro 8000
This can probably be resolved simply by adjusting the paper feed guide. Make sure that the movable guide (probably at the left side of the paper tray) is just touching the paper stack, with no gap.
Posted on Jan 10, 2010
SOURCE: how to print an envelope on the officejet pro
You have to remove the stack of paper, and then bring the "guide walls" to the center. Just found out. I haven't tested it but it should work.
Posted on Jul 01, 2010
  • 24 Answers
SOURCE: My new HP C309a will not connect to wireless network
From some guy name Bob who suggested to try downloading the Hewlett PAckard not the HP drivers .. this is a MUST do proceedure as HP drivers will not work with this printer.. we are attempting this at this momnet do not know if this is a solution or not but thought I would throw it out there...
Posted on Jan 02, 2011
I have an hp 8000 and it is printing blue in place of green
Use the software the printer came with and clean the print heads
Aug 05, 2012 | HP Officejet Pro 8000 Wireless InkJet...
What does it mean when the small drop shape is lit up on the front panel of my hp officejet 8000? The light that is coming on is the third one from the left
droplet shaped led indicates that an ink cartridge is nearing empty. The color by the droplet will indicate which color to change.
Jul 22, 2011 | HP Officejet Pro 8000 Wireless InkJet...
Hi, i have an HP Officejet pro k550 series printer and i dont know how to set the wireless setting, eg. IP configuration
If you printer has the optional Jetdirect print server istalled and you have a wireless router, then to configure this printer for your wireless network, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jul 04, 2011 | HP OfficeJet Pro k550 Printer
I want to run my wireless hp officejet pro 8000 wireless printer on usb cable and cannot turn off the wireless.
There is a button, on the printer, usually. This printer should be network cable attached and not USB. USB requries a host system and that host needs to be running and have sharing settings set to share.
MUCH better to connect the printer directly to your router.
Oct 17, 2010 | HP Office Equipment & Supplies
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
125 people viewed this question
k24674
jasbo
jasbo
