Question about Bosch 500 HMB5050 Microwave Oven
Over the last week the light on the inside of the microwave has dimmed and now it doesn't come on and the turntable doesn't work. Will replacing the light bulb correct the problem? Somehow the microwave does still heat food.
  • 909 Answers
I think you very possibly have a 2 part problem. Firstly, replace the lamp assembly, then replace the turntable motor. If you have a little electrical knowledge, place a tester on the turntable wires when microwave is on and check for voltage.Remember, run microwave as if you were cooking (Place water in unit when switched on).If there is power, then the motor is faulty.
Posted on Sep 27, 2009
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
I have a GE microwave. Beginning last night, the inside light stays on with the door open and when you close the door, the cooling fan starts up and the light stays on. The turntable doesn't rotate an
You have a major electrical issue within the microwave......potential electrical fire hazard. Unplug it and get a new one. Circuit boards are usually the same as the replacement price.
Nov 08, 2012 | Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Tried to replace the light bulbs on my microwave but bulb twisted in the socket and shorted out. my microwave still works but the turntable dosn't rotate and the light in the microwave dosn't light while...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation, inside light, and/or turntable, too.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jan 08, 2010 | Magic Chef CMV1000B Microwave Oven
Lights stuck on on microwave
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
Oct 05, 2009 | GE Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch 500 HMB5050 Microwave Oven Logo
167 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
