Trying to reduce copy to scan - Office Equipment & Supplies
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Legal size copies
Your printer doesn't support Legal size to Scan and Copy, you can scan/copy it by reducing the size of the paper from the menu. 10% will fit since the actual paper size supported by your printer is 8.5X11.7inch while the legal size is 8.5X14inch. Good luck. For more info check out here : http://h10010.www1.hp.com/wwpc/us/en/sm/WF06b/18972-18972-238444-12019-3328086-2511708-3643610-3643611.html
May 15, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Waste Ink Absorber is almost full
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a Pixma MP130 and I am getting the message "ink absorber is almost full". What do I need to do
1. Start Printer
Dec 15, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Scanner does not work. I get a pop-up error that says "SCAN WAS NOT SUCCESSFUL. IT THEN PROVIDES FOUR SOLUTIONS. I've tried all four several times and still nothing. I can make copies.
You MAY be scanning in too fine a detail setting which can run out of memory during the scan.
Reduce the resolution setting OR limit the area scanned to a smaller area.
Dec 09, 2009 | Lexmark X7350 All-In-One InkJet Printer
I HAVE A LEXMARK X9350 AND WHEN I SCAN ITEMS, THE FILE SIZE IS HUGE. EG 1 PAGE = 3MB. HOW CAN I REDUCE THE SIZE OF THE FILE
See the manual for X9350 on page 119.
The software application must be used for saving files to a specific format that you can select from the menu on the computer.
Standard scans are often saved as bitmap with the extension .bmp .
Select another file format like jpeg with the extension .jpg or .jpeg, when you want to view the scans in photoview afterwards.
Another option is to save the file in a format that can be read with Adobe Reader, selecting .pdf format.
A last option is to reduce your file size, changing the scan settings:
( I wouldn't advise; this can result in unclear copies ):
Advanced scan settings can be changed on the computer as well:
See reducing e.g. "scan resolution" and "color depth" on page 120.
Use the link support for Lexmark 9300 series for more help.
Sep 22, 2009 | Lexmark Office Equipment & Supplies
Shaded Background on the paper when making copies.
You need to clean the rollers and possibly change the ink cartridge.
Sep 05, 2009 | Canon GP-200 All-In-One Printer
How to use the scanner on my Epson 60000
there are different type of scannig programs. I am not that particular with your epson scanner. You can try scanning the document and if you want to archive it you can try choosig the option of file type as compressed tif. If you do not have this option there would be times that scanning software will have the preview of the document you have scanned and will asked you if you want to reduce or enlarge size. If resizing option is not available in your scanner software you can try saving it first in your computer. After saving the document try to open microsoft word and create a new file. Then look for the document you have scanned and copy that document. Once you have copied it go back to microsoft word and paste the documet. you could now resize the document manually. but for further clarification you can try calling your scanner provider. they might have some programs for it and will give it to you
Nov 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Brother dcp 7020 Scanning to e-mail
with Brother -photo capture-copy-fax-scan machine, I can do except scanning. Please show me how to enable scanning
Feb 01, 2008 | Brother DCP 7010 Multifunction Laser...
29 people viewed this question
jasbo
jasbo
