Question about Kenmore 53092 / 53094 Side by Side Refrigerator
M refrigerator isn't cooling the evaporator coil was full of dust it looked like it had a sweater over it but it still isn't cooling after I cleaned it what should I do
  • 146 Answers
Don't you mean your CONDENSER (the black tubes found at the back of your unit or below it ? Those are the ones that dissipate the heat - if they are at the bottom, there is usually a fan blowing air on it, if applicable, check to see if it is spinning, when the compressor is on.
The EVAP coils are the ones you find when you remove the freezer's back panel, you will see a fan there, blowing the cool air from the evap coils.
If the evap coils in your freezer are over frost it will cause cooling problems, in which case your defrost system is not functioning and you will need to change the control board and have the defrost components checked to make sure everthing else is working.
Posted on Sep 26, 2009
My electrolux ERN2820 is not working the light is on the moter is running but the freezer is defrosting and the fridge has lost it temp
Have you cleaned out the coils lately? Sometimes they become full with dust and will not cool properly. If the coils are clean, check that the fan is running. If the fan is running, maybe the compressor isn't. If the compressor is running and all else looks good it is probably low on freon.
Feb 03, 2012 | Electrolux ERN2820 Bottom Freezer...
Side by Side Can't find model # Not cooling enough
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
My refrigerator samsung is not cooling normaly please tell me normal temperature ??? I lost papers intrucions thz
First thing to check is the evaporator coil on your fridge. If it has alot of dust and build up on it, it will not cool properly. Take the front grill off the bottom of the fridge and check your coil. If it's really dirty, use a vacuum with a hose on it to clean. You can also use an old paint brush to remove build up.
May 08, 2011 | Samsung Full Option Side-by-Side...
Not cooling low enough
Hello, A refrigerator or freezer that is not cooling, but cooling poorly, may have a problem in one of several areas:
EVAPORATOR COILS or
CONDENSER
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust,lint,and dirt.
EVAPORATOR COILS:Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build up, is the presence of any frost or ice build-up on the inside walls,floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gasket.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. if one of the components in the self-defrosting system fails, the refrigerator continues to try to cool.
system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to off, and leave the doors open for 24 to 48 hours (be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually". When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat(also called the bi-metal switch)
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor.You may need to consult with a qualified appliance repair technician to further diagnose the problem.
CONDENSER: Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt, or lint, the refrigetator may not cool properly. The coils may appear to be thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and a vacuum cleaner to clean the coils of any lint,pet hair, etc. You may not be able to get to all of the condenser from the front , it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Thanks
Jun 20, 2010 | Frigidaire FRT18FS6C Top Freezer...
10 year old side by side fridge is slowly not cooling well
Well poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils - Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system- defrost timer, defrost thermostat (also called the bi-metal switch) or the defrost heater.
Secondly you can check Condenser - Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Maytag Refrigerators
Condensor line has frost on it and the fridge part isn't cold but the freezer works
Evaporator coils
Condenser
  • The defrost timer
Aug 03, 2009 | Refrigerators
Frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
Evaporator coils
Condenser
  • The defrost timer
May 27, 2009 | Refrigerators
Fridge and Freezer loosing their cold
Evaporator coils
Condenser
  • The defrost timer
May 23, 2009 | Refrigerators
The refrigerator is freezing in the drawers
Evaporator coils
Condenser
  • The defrost timer
Apr 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not cooling but fan and eveything else works
Evaporator coils
Condenser
  • The defrost timer
Mar 31, 2009 | Kenmore 52282 / 52284 Side by Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
139 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
