Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F1 error code replaced mother board twice but still have issues
I saw here about calling Whirlpool about the F! error code. The sent someone out free of charge to replace it. I didn't use my maching right away and it again wouldn't start. He said he much have gotten a bad motherboard. It took 3 weeks for him to get the replacement part and install it. I has been fine for the past three week but now it didn't want to start when I hit the power button. I moved it from normal wash to color and then it started up. I am starting to worry that I am going to issues again. Has anyone else had this issue.
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
2 Suggested Answers
  • 1028 Answers
SOURCE: Cabrio washing maching f40 error
problem is most likely the the motor position sensolean washer back remove motor rotor by turning big torx screw counterclockwise screw does not come all the way out ..remove 4 bolts holding stator assembly in place on the side of stator is a small connector with 405 wires pull the connector off and on 8-10 times ..there is a coating on the connector that prevents good connection on sensor reassemble and ck let me know how it turns out thanks
Posted on Jul 26, 2008
F1 error code
Call Whirlpool at 800-688-9900.
Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
They will send someone out to replace the controller board for free!
If not, here is a link to the control board you need.
Oct 16, 2012 | Maytag Bravos Top Load Washer
F1_Code on a whirlpool washer
washers have had several common repair issues since day one. If your Cabrio or Oasis washing machine has the dread error code F1, you can fix it. The F1 error code on you're washing machine means the mother board is bad. The repair is simple and straight forward if you are the adventurous type. The washers control panel needs to be removed to gain access to the mother board. The three screws on the back side hold the washers control panel to the cabinet. The screws are 1/4 size and a nut driver works best to remove them.
The washers main control board is held down with one small screw in the front. Removing the screw and lifting the board up is all that needs to be done to remove the control. The wire connections are all plug and play. The washers pressure switch hose also plugs into the main board. The pressure hose also simply lifts up and off the control board. Need more help? Post your question below i would be happy to assist.
Oct 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting a F1 code, how can I reset it. Can afford professional service.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Jul 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code F1 mean?? We seem to be getting it a lot when starting a load
Thank you !!
Jul 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Why does F1 code show and the washer stop on my whirlpool cabrio
Thank you !!
Jul 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error
Thank you !!
Jul 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
F1 error code, what is the part I need to fix this
The F1 error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I beleive Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Mar 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
Dec 07, 2009 | Cars & Trucks
F1 error on cabrio washing machine
Whirlpool Cabrio F1 error code - NOW A RECALL ISSUE! model # WTW6600SW2
  • I called Whirlpool 1-800-253-1301 today 10/15/08 and they said the F1 issue is now under a recall.
  • Whirlpool scheduled a repair service -during our phone call- to repair this under a 'recall' & at 'No Charge' to me.
  • I'll let you all know how it goes after the repair..
Nov 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What kind part i need to chang? when i get problem code f1?
Oct 26, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
