Question about Palm TX Handheld
Restting problem My TX resets itself after turn on. Only when I have a password enabled and I shut unit off on any screen other than my Browser, in which case the problem doesn't occur. I have TomTom Navigator 5 software installed along with the GPS Car Kit I have. When I turn unit on I get the password Key Pad for a second or two but it is unresponsive and then resets. then goies right to Navagator 5 opening screen. If I unable the password it is fine. I really like to protect my information with a password, but it is a real pain to have to make sure I am in my Internet Browser before shunting my unit off. I have tried a Hard Reset 2 times and reformated my SD card It did'n't help. I also like you to know I have a 4 Gig SD card 150x speed which works perfectly.
    Problem Solver:
  • 10 Answers
Sounds like a problem with third party software. Try removing your applications one by one until you discover the culprit. Or, back up everything (copy your backup folder to another spot on your computer as well), then hard reset the unit to bring it back to factory default. If it still happens, then it is likely a hardware problem. Otherwise, try re-installing apps one by one. Note, sometimes it can be the interaction of two apps that causes a mysterious problem like this.
Posted on Feb 24, 2008
Onkyo receiver tx-sr805 no display screen. how can i do a rest set? already unplug receiver per owens manual.
I'm sorta familiar with those kind of amps, lots have built in fuses. My guess is a fuse went
Nov 03, 2016 | Washing Machines
How to put a password in a router
Open your Web browser and type "192.168.0.1" (without quotes) into the address bar.
Press "Enter" on your keyboard to access the router.
A login prompt appears.
Enter your username and password to log into the router.
The router's main menu loads.
Navigate to the Maintenance heading of the Main Menu page.
Select "Set Password."
The "Set Password" menu appears.
Enter the router's old password into the Old Password field.
Type the new password into the New Password field. Verify the new password in the Repeat New Password field.
Click the "Apply" button to apply the change.
or if its the WGR614-V6 model
Push the "Default Reset" button on the back of the Netgear WGR614-V6.
The button is located on the back of the unit, to the left of the external antenna.
You may need to use a pin or the tip of a pencil to access the button.
Continue holding the button in until you see the "Power" indicator on the front of the unit turn off and back on.
This takes approximately ten seconds.
Let go of the button.
The Netgear WGR614-V6 shuts off and turns back on.
Allow several seconds for this process to complete.
Log into the router using the default password by opening a Web browser and navigating to the address "192.168.1.1." Enter the password "password" to log in.
hope this helps
Sep 20, 2012 | NetGear WGR614 Wireless Router
Hi have a Onkyo TX-SR601 after using it for a while it shuts down.
The problem could be bad solder connections on the main, or the audio outputs are breaking down when they get hot.
Mar 11, 2012 | Onkyo TX-SR601 Receiver
Need user manual for a Lanex/Verint netDVR. Also need the procedure to reset the netDvr to its default status. Thanks in advance for your assistance.
Let me guess - you aquired a netDVR with no hard drive and put one in and it doesn't work. The hard drives are encoded with some data that is specific to Lanex, so you have to buy the hard drive from them at a large markup. This is my only pet peave with Lanex as otherwise they are one of the best on the market. Do you have the application to talk to the netDVR? If you do then the default password is 'admin'. this should let you in to make changes to the configuration.
May 01, 2010 | Computers & Internet
KyoceraMita KM-4050: System Board reset for authentication
Login with 5050 as the username and password via the web browser and turn off authentication.
Nov 27, 2009 | Office Equipment & Supplies
I bought a used Palm TX Handheld can't clear previous owners password.....Can it be reset to change the password?
Yes it can. Hold the power button down and use the stylus to push in the reset button on the back of the TX. Keep holding the power button down till you see the screen powering up. Then let the power button go, you should see a menu asking if you want to reset the unit. select yes (qui). then it will clear all the data and password off.
Then download the latest Palm Desktop Manager and the Hotsync from this site:
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 28, 2009 | Palm TX Handheld
My samsung mp3 player is frozen on. It won't let me do anything, including turn it off. If I press the reset button will that erase everything on it? Anyone know how to fix this??
Reset the unit by holding down the REST button until the unit shuts off by itself.
Resetting the unit will not delete files off of the player
Jul 08, 2009 | Samsung YP-S5 MP3 Player
Palm TX handheld
First you need to reset the TX:
hold the reset button on the back of the unit, then turn the power on. Hold the power button while releasing the reset button. The TX will power up to the screen where it will ask you if you want to reset it to factory default.
Afterwards go to this link,
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
and download the Palm Desktop/Sync software and install it onto your PC. After installing the the Palm Destop software, connect the sync cable to the PC via the USB, then connect the cable to the TX and push the sync button.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 29, 2009 | Palm TX Handheld
My Xerox 416 S is printing confirmation reports before every job it prints. How can i make it quit?
  1. From the workstation open an Internet browser window.
  2. Enter the TCP/IP Address of the WorkCentre Pro in the Address field, then press [Enter] on your keyboard.
  3. Click on the [Print] tab.
  4. Under LPD settings, click on the check box next to [Enable LPD Banner] to insert or remove the check mark. When a check mark is displayed the Banner Page is enabled.
  5. Enter the password sysadm in the Password field, then click [Apply]. The Network Print Options Have Been Updated window will be displayed with a message stating that 'In order for the changes to take effect, please reset the printer from the Reset page or by turning it off and on again.'
  6. Click on [Reset]. The Reset window will be displayed.
  7. Click on the [Reset] button. A window will be displayed stating 'The unit is now being reset, allow 2 minutes before reconnecting.'
  8. Click on the [X] in the upper, right corner to close the Internet browser.
Apr 22, 2008 | Office Equipment & Supplies
Palm TX handheld turns automatically on and off.
If you tried a hard reset, and it is still happening... then it may be a hardware problem. Is it still under warranty? You may want to exchange it for a new unit.
Dec 16, 2007 | Palm TX Handheld
Palm TX Handheld Logo
57 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
