Question about Bosch 500 HMB50 1200 Watts Microwave Oven
Our Bosch heats up but the light doesn't come on and the plate doesn't rotate...the light dimmed over the course of say a week and now it's out... will replacing the light bulb make everything work right again?
  • 909 Answers
No, replacing the light and the turntable motor will be required.
Posted on Sep 27, 2009
Bosch hmc80151UC/01 (MW/Convection) not heating
MAN! I hunted and hunted for you but BOSCH is one of the poorest with support documentation! BOOOOooo... and I have a BOSCH dryer too that gets ''unhappy"...
MAYBE THIS will help you??
Of course, DISCONNECT THE POWER and DOUBLE-CHECK each fuse THERMAL FUSE and SWITCH!
That's all I can offer you my friend. METHINKS ONE of these puppies has to be bad!
Anthony
Apr 04, 2018 | Bosch Microwave Ovens
My Bosch Micro HMB405 started sparking/arcing with a burning smell. I had an empty plate in there. Was trying to warm a clear glass dinner plate. Did I kill the magnatron by putting an empty plate in the...
Michelle,
You may have killed the magnetron but you may not have either. If you can take that cover plate off, you may find that there is grease build up behind it and that needs to be cleaned off. Grease can build up there without you even realizing it and after a while it can catch fire from the heat created by the magnetron. You should never put any empty plate or container in a microwave because the magnetron needs to have something for the waves to hit. Hope this helps.
Mar 25, 2015 | Bosch Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Light's on, plate rotates, no heat
When the microwave works properly but just doesn't heat, then the magnetron is bad and will need to be replaced. You can get the part and the diagram at partselect . com or repairclinic . com
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave timer runs but turnable plate doesn,t rotate and the heating elements doesn't comes on
you need a new microwave. There are no heating elements in mocrowaves just micro-waces. It only heats moisture it does not heat objects. It is to dangerous to replace the actual device that heats liquids.
Jan 24, 2010 | Emerson Microwave Ovens
Over the last week the light on the inside of the microwave has dimmed and now it doesn't come on and the turntable doesn't work. Will replacing the light bulb correct the problem? Somehow the microwave...
I think you very possibly have a 2 part problem. Firstly, replace the lamp assembly, then replace the turntable motor. If you have a little electrical knowledge, place a tester on the turntable wires when microwave is on and check for voltage.Remember, run microwave as if you were cooking (Place water in unit when switched on).If there is power, then the motor is faulty.
Sep 25, 2009 | Bosch 500 HMB5050 Microwave Oven
Microwave lights up and glass plate rotates but no heat. Also, unsure how to remove microwave from its surround within kitchen unit.
to almost all of the no heat microwave issues suggest calling company about warranty because the warranty may cover problems like these up to five years and taking them apart will almost certainly void it. Magnatron is likely cause for problem.
Apr 21, 2009 | Microwave Ovens
Bosch 500 HMB50 1200 Watts Microwave Oven Logo
201 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
