Question about Dell W4200 42 in. HD-Ready Plasma Television
Have sound but no pic when it is turned on
Dell flatscreen monitor. I have sound but no picture shows when it is turned on.
  • cj33 Sep 26, 2009
    See three small green lights in back of the set coming out of the grill but that is it.
    Scholar:
  • 146 Answers
Look in the back of the set and see if you can see a light coming out of a grill, if not you probably lost your lamp or something related like the back light power supply. This is high voltage and if you aren't familiar you may want to call a professional to look at it.
Posted on Sep 25, 2009
Power light turns green then red no pic or sound
Hi David,
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 13, 2015 | Televison & Video
Dell's laptop cannot show the picture in screen.?
Connect to an external monitor and restart ur laptop. If the pic displays on the external screen then most likely you have a bad screen. If not then try reseating your ram chips. If that doesnt work get a new laptop
Jan 12, 2014 | Dell Computers & Internet
The screen on my acer aspire 3100 crack so i bought a vga cable to connect to my flatscreen but the picture switches back to my laptop when its starts up the only way that it works on my flatscreen is when...
Go into your display settings. It should show at least two different monitors. Your laptop monitor and the external one your plugged into. Click on the external one and click on the two check boxes. Click on extend the desktop into this monitor first. Then click on this is my main monitor. Reboot your computer and it should be on your external monitor.
Jun 12, 2013 | Computers & Internet
My 22" dell lcd flatscreen monitor just went out
I know it sounds stupid, but check all the cables and connection. Also make sure the cables are in good order.
Now with that out of the way. Is it getting any lights or indications of power at all? If so it could be a cable or connection point.
Worse case senerio, if your not getting any lights or indications of power (sometimes it seems like it should turn on) the monitor may have had a capacitor or power supple unit failure.
LCD can go out like that from long use or heat. If its older than 4 years its possible its done.
You can have someone open it up and check for budging or bad capacitors. This may be a cheaper option if you have someone is town.
Sorry to hear about the monitor. Good luck!
Oct 11, 2011 | Dell Computers & Internet
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
How do i test power on a dell flatscreen 1701fp. I have tested the power adapter and it is working and outputting the correct voltage. The monitor itself will not power on, I have disassembled and looked...
Since you cannot power on the monitor with the power switch on the monitor, then it can be the power supply or the logic board, or the inverter has shorted circuits so it makes the power supply go into shutdown mode.
This monitor uses 14vdc 3A power supply, so what you can do is to verify that you do have 14vdc at the DC input jack with monitor in the OFF mode, then try turn on the monitor to see if the 14vdc drops down to lower than 12vdc or so.
The inverter board has fuse also.
I do not have the pictures of the board for this monitor, but if you can post the pictures, then it will help a lot.
Does the inverter board look like this? http://www.badcaps.net/forum/attachment.php?attachmentid=12595&d=1259317517
At this point I will concentrate why the monitor will not turn on first, you can disconnect the ribbon cables attached to the inverter board and see if the monitor will power up.
http://s807.photobucket.com/albums/yy352/budm/DELL/
Aug 10, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
My dell monitor turns yellow after sometime... What can I do for it? What are the possible solutions.?
Under options for the monitor try degauss. This will de magnetize the monitor which may help.
Don't try to fix anything on the inside because old CRT monitors have dangerous capacitors
that can cause an electrical shock even when unplugged. Personally I would recomend getting
a new flatscreen. In the US they are pretty cheap even for a large screen, and burn much less electricity and look much better. If looking for a new monitor check online usually much cheaper
than big box stores. Newer models also have better refresh rates than the 1st ones that came out
so if your a gamer the performance of most newer flatscreens is pretty good.
May 16, 2011 | Dell UltraScan 1600HS D1626HT 21" CRT...
What could cause a dell flatscreen monitor to go
Probably a bad power supply in the monitor. One of these days it will go black and stay that way.
Dec 08, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
I have a LG 32 in flatscreen. It wont turn on. The green light blinks and I see the monitor light up some but no picture or sound. I can not see the menus or anything else. What can I do to fix this? I...
hi..the reason due to this problem may be
due to the circuit board.If the soldering is not
done in any part of the main board this type of
problem occurs.check the board completely.
check this out..
thank u..
rate me..
Feb 10, 2009 | Philips Televison & Video
I have a Dell flatscreen monitor that will not turn on. The power light blinks blue slowly
Hi...there,
It's seems you got a busted backlight inverter. If you still under warranty send it back to Dell for repaired. Happy Holidays!
Dec 18, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell W4200 42 in. HD-Ready Plasma Television Logo
32 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
