Question about Wagner 0513040 Paint Eater
It ran well for about 20 minutes and then stopped. I think it overheated and now will not start again. Could I have fried this thing in only 20 minutes of use and if so, what might a cost/options be for repair?
The engine cut out then right away was running again then 20-30 seconds later completly cut out again. After a few minutes it started again and ran for another two days. Then it cut out again, ran for...
- When was the last time this car had a tune-up? Could be as simple as that. New spark plugs/rotor/distributor cap/condenser might do the trick.
Other causes could be:
- bad fuel pump relay (definitely first on the list of things to check, and cheapest to fix)
- clogged/old fuel filter
- bad fuel pump
Mar 01, 2011 | 1991 Honda Civic
Ranger on a full charge stops working within 5 minutes. After 3 minutes or so, it runs again. Is the battery fried? Or is it overheating? It is aprox 1 year old. It is being run on flat ground. Please help
If power stops abruptly then theres a chance there coul be a loose connection and needs investigting. If power winds down and stopsthen yes the battery is probley fried.
Jul 16, 2010 | Polaris Ranger RZR Ride on Toy
No cycle runs longer than 20 minutes and the clothes are still dripping wet when done.
The motor could be overheating and shutting down. Does it stop mid cycle and the timer keep advancing? if so when it stops wait for it to cool down and try starting it again. If it will not start for a few min. then does it is the motor overheating.
Jun 23, 2010 | Washing Machines
Engine dies when hitting big bump
Yeah, I'd also think wiring, but do a check under the Distributor cap anyhow
Float stuck closed, something in the fuel filter got joggled around?
interesting
Nov 03, 2009 | 1987 Suzuki Samurai
Vacuum shuts down after 5-10 min of use
It may have a problem of overheating. If you havn't cleaned out the thing that holds all the dirt and dust, you may want to consider doing that. There might be a thermostat in it that shuts down whenever it thinks it's to hot.
Aug 20, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Dryer starts then immediately stops
sounds as if your motor is overheating nad shutting off.. willl it restart right away??? or will make you wait 20 min before restarting again only for 20 secs??? if so thats a bad motor
Mar 28, 2009 | Amana ALE230RAW Electric Dryer
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Mar 09, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Dusty smoking smell, stops working, trips out power in house.
you forgot to say if it is a 3 phase machine
if it is 3 phase then a phase in the unit is overheating and that will stop the machine then blow the breaker as all phases have to draw equal current
if it is a single phase then the start/ run capacitor or centrifugal start run points are not breaking at speed and so the start windings are overheating and causing the breaker to trip
Take it to an electrical motor rewind shop and have it properly tested with test equipment
Oct 21, 2017 | Hoover F6212-900 / F6215-900 SteamVac...
I have a Whirlpool Ultimate Care II electric dryer, model no. GEQ8858JQ0. For the past couple of days it has shut off after 20-30 minutes of running. After an hour it will start again after I press the...
motor bad ..most likely your exhaust vent is blocked and lint has built up around motor frame ..motor has probably overheated and damaged either the windings or bearings
Aug 03, 2008 | Whirlpool Dryers
Wagner 0513040 Paint Eater Logo
81 people viewed this question
Top Wagner Tools & Hardware - Others Experts
Craig Butler
Craig Butler
eyecam
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
