Question about Tomtom ONE 3rd Edition GPS
Tomtom one 3rd editon will power itself on occasionally. The battery has benn over heated setting in he car. Will charge up and work well while on automobile power.
SOURCE: tomtom one 3rd editon initial home address incorrect
10 outstanding
Posted on May 18, 2008
E61N
  • 515 Answers
SOURCE: TomTom one 3rd edition
Try a reset:
http://www.tomtom.com/support/index.php?Language=1&query=reset&FID=6965
If to no avail, return it to dealer..
Posted on Jul 27, 2008
  • 4090 Answers
SOURCE: my tomtom wont charge through car charger or pc
It is possible that the cvar charger fuse has blown. Undo the tip and remove and replace !amp fuse and all should be fixed.
Please rate my help++++Thanks for using FIXYA
Posted on Dec 08, 2009
  • 5 Answers
SOURCE: TomTom One 3rd edition - started to not charge
The TomTom One 3rd edition battery can be replaced if you are up to some work on your part with the Li-ion Battery 1350mAh Black CS-TM600SL! You will need to take off the back of the tomtom first! Now the connector on the old battery wires are not the same as on the new battery so the wires need to be spliced and soldered back together using the old connector off of the old battery! The new battery will last about 2.75 hours! Don’t try this if your unit is under warranty! The tool to take off the back can be bought at any auto parts store for just a few dollars! And you will need a flat tipped screwdriver to pry the back off! The tool needed to is a soldering iron and solder! The new battery can be bought at E TechTronics.com! Good luck if you’re up to it! The original battery is not sold anywhere that I know or can find!
Posted on Dec 19, 2009
  • 4090 Answers
SOURCE: tomtom one 3rd editon hadn;t been used for some
leave it on charge for 24 hours. if nbo recovery get a new battery
Posted on May 29, 2010
Power light on when pluged in but won't start tomtom one new 3rd edition
How long do keep it in charge? was it unused for long time?
if it was not in use for more then 20days then pls charge it atleast 2hrs and try. still does not work then ur battery needs to be replaced.
Jul 30, 2010 | Tomtom ONE 3rd Edition GPS
Tomtom one 3rd editon hadn;t been used for some
May 29, 2010 | Tomtom ONE GPS Receiver
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
Nov 01, 2009 | Tomtom ONE 3rd Edition GPS
The tomtom turned off by itself while I was driving and I cannot turn it back on.
make shure your battery is charged and on the bottom there is a reset button try that.
Oct 15, 2009 | Tomtom ONE 3rd Edition GPS
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
I tink it is a battery problem
It's impossible to find a battery for Tomtoms at places like radio shack--it's an off-size. Your best bet is ebay--lots of them available there inexpensively. Or just google tomtom battery for other online retailers. Tomtom will replace them for you (matter of fact, I'm pretty sure it voids your warranty to try and replace them yourself), but they charge so much it's hardly worth it for the less expensive units like the One. It's easy to do yourself, but you need the right tool, a size 8 or 9 (I don't remember off hand which it is) torx bit screwdriver, which is itself a little hard to come by (try an auto parts store).
Mar 19, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom one 3rd ed only turn on one time now it will not turn on
Hello, Unplug your Tomtom device, batteries should be fully charged. The tricky thing to Tomtom devices is the ROM put into the device. It needs to be reset once in awhile. The soft reset is like formatting a hard drive but leaving the system files alone. At the bottom of the device, there is a reset button. You'll need to use the end of a paperclip to reset the unit. After it's reset, reinstall the Tomtom application only by using the Tomtom Home application. Let it reset itself and come back to the original screen, then go to menu and set your preferences. Also if it's connected to Tomtom home and if you backed up your data to your computer, reinstall your maps. The only time your Tomtom device gets bogged down and won't finish a reinstall is when all 1 GB of memory is used up. Hope this helps.
Jan 11, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom one 3rd editon initial home address incorrect
Tap screen, tap Change Pref., tap Right Arrow, tap Change Home location.
(Please rmember to rate, thank you.)
Apr 10, 2008 | Tomtom ONE 3RD EDITION GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
