Question about AEG Dryers
How do i fix the tub from not spinning
How do i fix the belt to make the tub spin
  • AEG Master
  • 7,482 Answers
You did not say if it was broken or not...
If it is broken then it must be replaced.
If it is not broken, then it must have came off the pulley or the drum.
you have to pull the front of the dryer off and remove the drum to reinstall the belt on the pulley and the drum
Posted on Sep 25, 2009
Front load washer wont spin
Check for drain obstructions. Might be something caught up in or near the drain pump. If water drains out of unit with no problems, check the belt. Motor could be issue as well. If you reach inside the tub where you put your clothes in, and grab one of the paddles, see if the tub itself moves back and forth and up and down. If you have a lot of free play or movement with the tub test, sounds like your spin bearing may have failed. If it is the spin bearing, not worth fixing.
Feb 18, 2015 | GE Washing Machines
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Clothes washer tub spins on wash
sounds like u have a problem with the "brain". The agitator and spin cycle should never run at the same time. therefore it leads me to A: brain issue B:problem in the actual transmission of what cycle should be running. You will continue to smell the burning rubber due to the issue being one of the two explained above. Does it ever NOT spin? If this is the case the likely hood is that it will be a solenoid.
Apr 21, 2013 | 2000 Honda Accord
Is off balance during the spin cycle mor often
I have a 10yr old Maytag Atlantis model MAV7258AWW. Here is how I solved my balance problem. It appeared that I had two problems. One was that it would not spin fast, the second was that it would spin off balance. To get the washer to spin fast like it should I had to open the lid then close it, re-engaging the spin cycle. I opened the top and watched the motor engage in the spin cycle. with the top open, I would open and close the lid activating the lid switch. Each time I closed the lid I noticed that the motor would move a little bit more on its glides to tighten the belt. Sort of like a automatic adjuster. The motor is designed to pivot one way for the agitator the other way for spin. If the motor does not pivot correctly, the belt will not tighten and will slip. I removed the front panel, cleaned and lubed the pivot area. Now the motor glides on the pivots like it should. I ran the spin cycle and the motor slid all the way to one side like it should, the belt tightens and the spin cycle spins. Now that the spin cycle works, quess what?? The balance problem is fixed as well. It appears that the reason that the tub was going off balance was because the belt was slipping not spinning the tub at maxium speed as designed causing the off balance problem. The tub was not spinning fast enough causing the off balance problem. I have ran several loades in the washer and not a problem. I did replace the snubber, it was worn out but it still spun off balance. I hope this helps to all who have a balance problem.
Mar 02, 2010 | Washing Machines
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Belt spins but tub won't somtimes during spin cycle
Worth going at this a bit at a time.
First look at the routing of the belt. What keeps it tight? has anything that ought to be keeping it tight worked loose?
Now take the belt off and spin the tub by hand. Does it move freely? Does it make any funny noises? Does the motion feel lumpy or gritty? This will help you decide whether you have a bearing problem or an old sock that's got where it shouldn't have.
If either of these tests hints at a problem, investigate further and fix it.
Then, regardless of whether you found or fixed anything, fit a new belt. Quite often the problem is just that as they get old, they stretch and then don't grip so tightly - and if it has been slipping because something else was loose or stuck, the heat generated will since have made it stretch anyway.
A.
May 29, 2009 | Maytag Washing Machines
Hi, I have a Maytag Washing Machine. Model Number: LAT7793ABV It seems to wash fine, but when it gets to the "Spin" part of the wash, sometimes it doesn't spin, and if it does spin, the clothes...
Several items can cause no spin or slow spin. I'm assuming the motor runs during spin and the water all drains out. A worn or damaged belt can cause your problem. Always replace the drive belt and pump belt at the same time.
Check for smooth and non binding motion of the motor in it's carriage.
A failing bearing (either tub bearing or spin bearing) will restrict tub motion in spin.
A garment in between the inner and outer tub will also restrict tub spin performance.
Apr 28, 2009 | Washing Machines
Dryers Logo
65 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
