Question about LG W2252TQ-PF 22" Monitor
Monitor keeps flashing up the lg logo and cannot get rid of it
I have had this monitor now for around a year,the first one i had when i bought it had lots of dead pixels,so was exhanged.Now i can be in the middle of using the pc and suddenly the screen will go black and the lg logo keeps flashing on and off,the pc is still running as you can hear the sounds etc of programmes i am using,but even by moving the mouse you cannot get any image back,you have to unplug the monitor and plug it back in but after a few moments it does exactly the same thing,have checked all connections on it,and also tried the monitor in a different pc but same thing happened within a couple of minutes,it does have 3 yr warranty on it but i have lost my receipt and have been told i cannot do anything without it,i havent had much luck with lg so far is this a common fault and can it be fixed or am i gonna have 2 buy yet another new monitor
ginko
  • 19396 Answers
SOURCE: My Lg Monitor wont show screen (Power Button Flashing)
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 04, 2009
ginko
  • 19396 Answers
SOURCE: LG1717S - Power light flashing - no image.
  • Video cable.
  • Motherboard.
Posted on May 22, 2009
  • 1684 Answers
SOURCE: LG L226WTQBF black screen with blue light on power on button
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 14, 2009
prashanthcl
  • 460 Answers
SOURCE: LG W1934S monitor. It displays an image for about
first you ensure that it is a problem with TFT or CPU. you can check it with another monitor. if it is working with another monitor then your TFT has been faulty.then you can repaired it from service center.
Posted on Nov 04, 2009
Testimonial: "Good direction for me to persue."
indus3
  • 212 Answers
SOURCE: the auto image adjustment text displays on screen automatically
you can enter the OSD of the display and turn off the automatic display config. you can find a description to do this in the display's user manual.
Posted on Apr 21, 2010
I bought a new Dell Pc and I keep getting flashes in the upper left hand corner. How do I get rid of this? Thanks
When you say flashes, is it like portion of the screen flickers?
If the flickering/flashes starts in Dell screen just right after turning on the laptop, when you see the Windows logo or just right after you log in to windows?
Try connecting your laptop to an external monitor then toggle display. To toggle the display to external monitor you can try holding down keys such as the function keys.
If the problem persist from the external monitor it means the problem is the motherboard or the video/graphics card.
If no problem from the external monitor this means laptop LCD and LCD cable needs to be replaced.
Hope this helps.
Jun 02, 2011 | Dell Computers & Internet
My lg chocolate won't turn on, just keeps flashing the Verizon Logo
Flashing the logo means that the LCD is fine and kicking. You must get the phone's firmware reinstalled. The reason of flashing Verizon Logo is that it cant read or follow the instructions beyond the logo stage. So, give it the stuff to read or follow. Reinstall the firmware and you will find that everything moves smoothly.
Dec 11, 2009 | LG CHOCOLATE VX8500 Cellular Phone
LG 17" flat screen monitor one old, all red is gone from display
Did someone change the setting on the monitor itself ? check those settings and then check the setting on your graphics card, sometimes you can change those setting and it will effect the color that you are seeing
Oct 09, 2009 | LG Flatron F700P 17" CRT Monitor
EMachines monitor keeps flashing the On Screen Display menu.
if it is the button. you would have to open the monitor and fix it that way, and i dont suggest doing that yourself, unless you are familiar with electronic components. take it to a repair shop. call around and get an idea of who would do the best job for the best price.
Let me know :)
Dec 22, 2008 | E-Machines eMachines Monitor E15T4
The display menu keeps flashing and i can't get rid of it.
Bad control chip, mine has the same problem. If under warranty - send it in. I just tossed mine and bought a different LCD.
Nov 08, 2008 | Samsung SyncMaster 720N Monitor
LG W2252TQ-PF  22" Monitor Logo
109 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
