Question about Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1280 blinking lights
I have an Epson Stylus Photo 1280 I changed black ink cartridge and now the red and green lights continue to flash and printer will not print. if I turn off the printer and turn it back on it will start the cleaning process but will then go back to the far right position and the lights start to flash
  • Kirk Augustin
    Kirk Augustin May 11, 2010
    If it did not do it before, and it does now, then you screwed something up when you changed the cartridge. Try taking it out and putting it in again. Maybe it did not seat right? Maybe you left a seal on it?
SOURCE: Epson Stylus C62
hi can u give me Epson Stylus C62 InkJet Printer driver
u can send it b balsam_shatry2000@ahoo.com
Posted on May 27, 2008
The Machine
  • 788 Answers
SOURCE: I have an Epson 1280
This is an indication that your ink cartridge(s) is/are low or empty. Replace the ink cartridges and printing should resume.
Posted on Jul 02, 2008
eclark317
  • 159 Answers
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
gwbm
  • 353 Answers
SOURCE: Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
Posted on Mar 15, 2009
sherlyn c
  • 134 Answers
SOURCE: I need a repair service for EPSON stylus photo
Please log on to epson.com. Click on north america, then usa. Go to the drivers and support page. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
Posted on May 04, 2009
I was printing several pages & it just stopped working. the ink button & on button flash. Changed the ink cartridges but still get the same blinking with no printing. Turned both the computer...
Press the Ink Cartridge Replacement button and check the flash pattern of the control panel lights:
ERROR and POWER lights flash at the same speed = replace black cartridge
ERROR light flashes twice as fast as the POWER light = replace color cartridge
Jun 04, 2010 | Epson Stylus Photo 1280 InkJet Printer
The green and red lights are on.They arent blinking just on.And when i go to print a job nothing happends.
The green light is the power light, the red light indicates out of paper or an empty ink cartridge.
Dec 05, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus photo R230 Desktop : Printer icon flashing with exclaimation mark `No Ink` changed Black Ink cartridge in printer , Red & Green lights on not flashing Please help.. how do you know which...
go to the printer setting under control panel, right click on the icon then properties..you can check the ink level there...normally if your printer blinks and ask for a new cartridge..better follow what the printer says... : >
Aug 31, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo 1280 Isn't the printer working if I only have a black ink full?
It doesn't matter whether the cartridges are full, but both cartridges need to have ink in order for the 1280 to work.
Jan 17, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Ink cartridge unit will not move to replace
Printer has pads for excess ink, once pads are full this happens.
Pads will need to be replaced
Jun 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280
Go on line and down load this utility www.ssclg.com When program is installed- double click on the the icon in the lower task bar and select the printer type. Then right click on the icon in the lawer task bar- there you will see a range of tool to manipulate the printer ink system- try -reset black.
May 08, 2007 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo 1280 InkJet Printer Logo
149 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
