Question about Eclipse Car Audio & Video
Replacement security cd for eclipse cd 3404
Do you know if you can just buy the security reset cd for the eclipse cd3404?
  • lwaterusa Mar 07, 2008
    I purchased the Eclipse CD3000 CD Player on line from a liquidator and it didn't come with the security cd. What do I need to do to reset the unit?
  • Anonymous Jun 15, 2008
    I bought a eclipse cd3404 and need to take off the lock how do I do it
3 Suggested Answers
  • 105 Answers
SOURCE: CD Ejects
A couple of suggestions. Check ALL the fuses, most units have 2 or more. Search the front panel carefully, many units have a tiny 'reset' switch, which is activated by pushing a pencil point into it's hole. They are usually marked, but with tiny letters.
Posted on Jul 17, 2007
sodeep
  • 3267 Answers
SOURCE: my eclipse cd3404 player is off
If you are the original owner, you should be having the CD which you played first. That CD acts as a key as an anti theft protection. However if do not have the CD then ring up eclpse and have your Serial Number ready at hand. They are the only ohes who can help you out to make a new key. This happens every time the battery is disconnected. So all the best............sodeep
Posted on Aug 03, 2009
No security code audio system
These units do not have a security code like some radios. Instead, they are coded using a CD. You insert a CD into the radio and it codes to that disc. You need that same CD if you ever want to unlock the player. If you don't have it, you are SOL. Eclipse is no longer in business and they were the only ones that could reset it. The system is known as "ESN Security".
ESN Security: This unit is equipped with the Eclipse Security Network. You can register a particular music CD as a "key" device which unlocks the security. If the registered CD is not detected, the navigation and audio functions will be disabled when the main unit is disconnected from and reconnected to the vehicle's battery.
Dec 16, 2013 | Eclipse CD2000 CD Player
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
Oct 28, 2010 | Eclipse CD3422 CD Player
My eclipse cd3404 player is off and tells me to call 800SC502970 what do i do? happened after new car battery.
Aug 03, 2009 | Eclipse CD7000 CD Player
No security cd for eclipse cd5435 player
take it out throw it in a bin and get a good stereo my advice but honestly go to a dealer ship and pay their outrageous amount for a cd
Jun 15, 2009 | Eclipse 5340
Car stereo lock up
Hi basic101
There is a security cd that comes with the unit originally. You use that to reset the code. without it, is difficult to fix here in this forum. .
There is also antoher way, if you had the unit installed,try playing the first Cd you ever played on the system. That apparant;y is a method for unlocking them also.
Other than that, you may need to get the serial number off the unit and get in touch with your local Eclipse Authorised repair guy.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 21, 2008 | Eclipse CD5405
Security CD
The security CD is the 1st CD you put in after reset.
For example: If you go to the shop and have the radio reset. On the way home you put in Jimi Hendrix, that CD becomes your security CD.
You better have that CD the next time you change your battery, or you'll be going back to the shop to have your radio reset.
Jan 09, 2008 | Eclipse CD3422 CD Player
Eclipse AVN-5435
for avn 5435 on the left:press menu and cont ant the same time, while holding them down press menu on the right 5 times
a menu will appear and ask you for a code. you have to call 800-233-2216 and pay $25 for the code. you will have to explain where you bought your eclipse and or know the name of the original owner. if it doesnt match they will not give it to you
Dec 07, 2007 | Eclipse AVN5500 Car DVD Player
CD Ejects
Jul 17, 2007 | Eclipse CD2000 CD Player
Eclipse 5340 deck
I forget about the security light but I do know about the clock. I believe you turn the deck off and hold display or push display and the clock will come up. Then use the preset buttons for adjustment. I think 1/2 is for the hour and 3/4 are for the minute. It has been a while for me doing this but I think it is right. I just powered mine back up a while back and am trying to find my starting cd. You wouldn't happen to know how to reset this function and start over?
Apr 11, 2007 | Eclipse 5340
Car Audio & Video Logo
394 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
