Question about Garmin iQue 3600 GPS Receiver
Can the IQ Sound 8600 camcorder/digital camera record for an hour or more without downloading?
The problem of my camera is that no sound appear when i record a video..how can i solve this problem,thanks.
Hi music_divina ,
This could be due to the fact that you have a digital camera without an inbuilt microphone in it.
Usually camcorders do have in built microphone so that you can record sound as well as video simultaneously, whereas digital cameras are meant for high quality pictures , rather than videos.
So if you want to record good quality video along with audio , I would recommend you to get a camcorder.
If you have a webcam and you want to record audio along with video , then you can easily do it by using the microphone which is to be inserted in the mic slot just besides the speaker's slot with a microphone icon near it.
All you need to do is select the video recording source as your webcam and audio recording source as your microphone and there you go , you have the recording with audio.
Hope this helps ...:)
May 11, 2011 | GE Cameras
I can not find the manual to my iq-8600 camcorder. Is there a downloadable version online?
You can download the manual from
http://camera.manualsonline.com/manuals/mfg/supersonic/iq8600.html
Please rate this solution. Thanks.
Let me know if you have any other questions.
May 03, 2011 | Cameras
Does Vivitar Camera 8025 record Sound? My
Unfortunately that's the way it is. The ViviCam does not record sound. It's basically a still camera with a little video capability grafted on. It's not a camcorder.
May 10, 2010 | Vivitar ViviCam 8025 Digital Camera
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Battery pack for Canon ZR100 digital videocassette camcorder
For good spare canon nb-2lh battery,or cheap replacement canon nb-2lh digital camera battery,you can search and searh to find a famed relible camera camcorder batteries store with chargers on sale,shopping online convenient and cheap !
Jun 25, 2008 | Canon ZR100 Mini DV Digital Camcorder
Set up recording speed on hitachi camcorder
I have digital video camera recorder DCR-TRV265E PAL. How can i Download my saved video on my pc
Jun 04, 2008 | Video Cameras
Camera stops shooting by itself
if its sound is beeping, it means the mechanism have an error. Check the small fuse of the power supply
Jun 03, 2007 | Canon ZR200 Mini DV Digital Camcorder
DV-PC recorder
DV-PC Recorder is a Windows XP only application that enables you to record images and sound on the tape in the camcorder and on the computer's hard disk by connecting a camcorder equipped with the DV CONTROL function to a computer using an IEEE1394 (DV) cable. DV-PC Recorder has the following features. 1. You can record movies simultaneously on your computer's hard disk and on the tape by pressing the start/stop button on the camcorder. 2. It enables long, continuous recordings, which you cannot achieve with the tape alone. (Approximately four and a half hour's worth of recording will fit on a 60GB hard disk.) 3. You can start editing the movies on the computer right after recording, as the images and sound are saved on the computer's hard disk. (Optional editing software is required to edit movies) 4. You can record movies on the tape in the camcorder and on the computer's hard disk by controlling the DV-PC Recorder from your computer.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Sound Problem
Digital video camcorder are recording signals in very thin line (as thin as 1/8 of a hair.) Therefore, following symptoms may appear if video heads become dirty even a little. Video heads may become dirty under the following conditions: (1) When using the camcorder in humid or hot places. (2) When using cassette with damaged or dirty tape. (3) When using the camcorder in dusty places. (4) When using the video heads without cleaning them for a long time. Note: Before you make important recording, clean the video heads and make a test recording first. We also recommend cleaning the video heads after use before storing the camcorder.
Garmin iQue 3600 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
