Question about Poulan Garden
NO SPARK TO THE PLUG
    President:
  • 2,220 Answers
The most likely cause is the incition module (coil). It may also be the run/stop switch or interconnecting wiring. You give me no model number & I'm not certain it is a Poulan. I can't give you a more complete answer given what you provided. HTH
Lou
Posted on Sep 25, 2009
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Replace spark plug's
Things you will need
Spark Plug Socket And Wrench of the correct size for your spark plugs
Basic Instructions.
Step 1
Locate your spark plugs
look for other obstructions besides your spark plug wires
if you have any other obstructions you will need to remove them as well to gain access to your spark plugs.
Step 2
Remove the spark plug wire for one single spark plug at a time.
this will insure you will not replace the wrond spark plug wire to the incorrect spark plug,
if not done this way you could change the firing order of your engine.
Step 3
With your spark plug Socket and wrench rotate the spark plug in a counter clock wise direction for removing.
Step 4
After you have removed your spark plug insert your new replacement spark Plug into your spark plug socket before inserting it into the correct location. spark plug sockets are made to hold on to the spark plug for easy removal and install.
Step 5
insert your new spark plug,
before you rotate your spark plug for tightening rotate the spark plug a 1 quarter turn in the counter clock wise direction, then start tightening the spark plug by rotating it in a clockwise direction
This will insure you will not strip the threads.
Step 6
Continue rotation your spark plug in the clock wise direction untill snug, then with just a lil more pressure tighten it up just a little more.
be sure to not put to much force on the spark plug after it has been snug, you just have to apply a little more pressure but not to much that could cause it to break.
Step 7
After tightening the spark plug replace the correct spark plug wire.
then move on to the next spark plug and follow the same instructions.
if you have any other visiable obstructions preventing you access for replacing your spark plugs you will need instructions on how to remove them parts. i have just instructed you on how to remove and reinstall the spark plugs only.
Feb 16, 2013 | 2008 Mazda Tribute
Not getting spark out of spark plugs
For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
May 28, 2012 | 1996 Ford Contour
Wont start no spark on spark plug
Car has no spark?
This will help.
Thanks.
May 24, 2012 | 1990 BMW 525i
1994 mitsubishi expo not getting a spark to spark plugs
Car has no spark?
This will help.
Thanks.
May 11, 2012 | 1994 Mitsubishi Expo
No fire to the spark plugs
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
-----------This will help.Thanks.
Feb 23, 2012 | 1993 Honda Accord
Sparkplugs no spark
Car has no spark?
This will help.
Thanks.
Feb 04, 2012 | Polaris ATV
Garden Logo
46 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
