Question about JVC HD-61FN97 61" Television
How do I manually adjust overscan on a JVC HD-61FN97
I have massive overscan when sending 1080p output from my PC. Is there a screw or knob inside the HDTV which can reduce the picture size, so I can remove this overscan? I don't care if the other inputs are messed up in the process, as I only use this as a PC monitor.
A smaller issue is the picture is off center a bit, so I have to reduce the resolution even more to account for the misalignment of the projector. Can this be adjusted as well?
To be clear, I have electronics experience and don't mind removing the back panel and tinkering around to fix this issue.
SOURCE: Problem with JVC 52" TV picture
Converge chips are bad
Posted on Sep 26, 2007
tvtek
  • 1284 Answers
SOURCE: jvc hdmi????
Changing the output to digital only affectts the audio output stream such as Dolby Digital or DTS audio. Try turning on the DVD player first then the television and see if then it sees the DVD player. Otherwise using the component outputs most will never see the difference n picture quality. Good luck.
Posted on Dec 12, 2007
SOURCE: HDMI no longer working
Hey, it is another service menu screen. you access it the same way, except push the sleep timer button until you see 30 min, then push display and video status. self check is #2. if any of the categories has "NG" followed by a number, that means that the is an error. See what you can find out.
Posted on Feb 20, 2008
  • 9 Answers
SOURCE: Replacement of front plastic screen
well, unless you are really really lucky and could find the same model at the local tip, you will need to ot\rder and replace the part through a repair center or parts center of sorts, quite costly
Posted on Mar 17, 2009
  • 864 Answers
SOURCE: JVC HD52FA97 PC input won't fill screen.
Check your manual to see what it says about picture aspect for PC input.  My Panasonic looks the same way that you describe and the manual says it is supposed to look that way for PC input.
Posted on May 29, 2009
I have 1080P jvc hd-61fn97 free service manual wear can i find one
Not likely since all JVC manuals are online and only to authorized service centers, try to Google and good luck.
Nov 29, 2012 | JVC HD-56FN97 56" Television
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
Can you adjust pincushion, overscan on Sony kdf46E3000?
Steve, I am not an expert on this model but I can provide a link to the manual that may be helpful. It is a PDF format and the pages that refer to your issue are 32-36. I hope this assists you in resolving your issue. Thanks for using Fix Ya.
http://www.retrevo.com/d/ds/progress?doc=422217ceb653da53024f151f0e38f2ce&rk=0.4228925186481609
May 15, 2012 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
No sound on my jvc since cable hooked up? Ive tried everything help!!
Try clicking on this link I found to help you: www.manualowl.com I hope this is of help to you, Amanda! Best to you, Jimmy
Apr 11, 2012 | JVC HD-61FN97 61" Television
I need a new screen for my tv it got broke. Its a jvc HD-61FN97. I need to get a price also.
you may have to contact JVC tech & customer service , heres a link:
http://support.jvc.com/consumer/support/index.jsp ,good luck , please rate ME , thanks AJ
Oct 26, 2009 | JVC HD-61FN97 61" Television
JVC HD-61FN97 rear projection TV does not have any blue colors showing.
your blue componant cable is unplugged, eather on the tv, or on the cable box, 95% thats the prob, thats if you are using componant cables, those are red blue green, and red white for the audio
Jan 07, 2009 | JVC HD-61Z886 61" Rear Projection HDTV
No sound on my JVC HD61FN97, is there a reset on the TV?
Thats great, have nice time
You can get help nearby qualified TV tech to check audio amp in TV.
Dec 25, 2008 | JVC HD-61FN97 61" Television
TV does not show picture
have you checked the bulb? they do break down. if the bulb is good condition, have it send to a repair man.
Oct 13, 2008 | JVC HD-61FN97 61" Television
Aug 05, 2008 | JVC HD-61FN97 61" Television
Magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
JVC HD-61FN97 61" Television Logo
324 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
